automatic windows won't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ws309, Mar 2, 2012.
  1. ws309
    ws309 Junior Member
    22
    ventura
    2009 Prius all windows stopped working except the drivers window.I have checked fuses,window locks,etc...I heard that the problem is the "bcm" which is located under the drivers seat. One window was half way down when it stopped working so I took the door panel off and ran wires from my laptop power supply and ran it up. I am wondering if i could run a wire from the battery with the correct fuse on it to each window and bypass this '"bcm" thing altogether.
  2. rcturner
    rcturner Junior Member
    53
    It would not be safe even if it did work. All of the safety and logic features that are built into the computer would be lost. Also, I would think that you could be legally responsible should there be any mishaps in the future even if they are beyond your control.
    Don't do it.
  3. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Is your window lock on?
  4. jas1178
    jas1178 Junior Member
    44
    St. Petersburg, FL
  5. sandrajolly
    sandrajolly New Member
    Tennessee
    It might need a whole new motor. But first check the fuses in the fuse box and make sure you don't just need a new fuse. To put in a new motor, you have to take the whole door panel off and it is expensive labor-wise and parts-wise.
    Hope I helped you!! :)
  6. ws309
    ws309 Junior Member
    22
    ventura
    no window lock is not on and it is the "ecm" that is suspect.
  7. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Are you able to check/read car diagnostic codes? It can be more serious problem, than just a window logic. I would not recommend to bypass ECUs. And yes, you are in wrong forum.
  8. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the gen II maintenance and troubleshooting forum.
  9. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    The body control ECU is not under the seat it is located in the dash. See below.
