automatice headlights
Discussion in 'Gen 2 Prius Main Forum' started by fred, Feb 5, 2004.
  1. fred
    fred New Member
    235
    nashville
    question, does the prius have automatic headlights or daylight running lights. im so used to them on my other vehicles that ill miss them a lot.
    fred
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I leave the lights on all the time, and open the door right after I stop to turn them off.
    When it's sunnier more during the summer, I'll probably not do it this way, but lately I end up needing the lights while I'm driving anyway...
  3. olends
    olends New Member
    214
    Clifton Park, NY (near Albany)
    the short answer is no, the prius does not have either. it was supposed to be there, its in the manual, but its not on thr car.
  4. DaveG
    DaveG Member
    806
    Vancouver, BC
    Unless you're in Canada, where our version has both Auto headlights and DRL.
    Dave
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    We figured out from the NCF docs that Auto headlights required DRL. DRL's are not available in the US.
    Conversely, cars with HID headlights could not have DRL's, and since DRL in Prius uses the main headlights, Canadian Prius didn't get HID lights (could be other laws there as well).
    I suppose with enough work and some parts, non-HID Prius owners could incorporate DRL and auto-lights if desired.
  6. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I'm sure if you wanted to sit down and figure out the wiring, you could make the fog lamps into your DRLs. Just a thought.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Rick hit the nail on the head, regulations, in Canada DRL's are mandated by law, have been since the mid to late 80's. Also on the CDN modles that have auto have an additional photo cell on the dash, If you have the inclination to check a non HID Prius and see if it has 2 cells on the dash that would make the puzzle easier. As for using the fogs as DRL's it's very easy one relay one diode and a fuse and some wire and just have the relay coil take power from the "ignition" side of the key and and thru a diode to the power for the headlights and the power side thru a fuse and thru the contacts in the relay to the fog lights. Two more diodes and the fog lights still function as fog lights, just send the power from the fog light switch thru a diode to the lights and the "DRL" feed thru a diode to the lighs and your done. I do know there is a small voltage drop thru diodes but hi current diodes would more than handle this kind of load.
  8. randalla
    randalla Member
    370
    Lexington, SC
    Having had daytime running lights on several cars since GM introduced them in the US, I'm going to miss them when I trade in my '03 Vue and take delivery of my long anticipated Prius. Just wondering, do the fog lights work independently of the headlights or must they be only be used when the low beams are turned on? Also, has anyone looked into how they could be turned on and off independently of the headlights so they could be used as DRLs?
  9. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Unfortunately, as best I've been able to Determine, the Fogs are only available when the Low Beams are already on.
  10. randalla
    randalla Member
    370
    Lexington, SC
    Thanks, Tempus. That's pretty much as I expect it would be with the fogs. Has anyone else had different experience with the fog lights as DRLs?
  11. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Fog lights may come on with the parking lights, but they do turn off with the high-beams - that's fairly standard.
  12. Ken Cooper
    Ken Cooper New Member
    339
    Wasn't it stated by someone earlier on this forum that when you leave your Prius and not turn off the headlights, the headlights will automatically turn off? I always drive with my headlights on. I hope this is the case.
    Driving with headlights turned on, even during the day, makes your car easier for others to see. That's a good thing ... Less chance of an inadvertent crash.
    GM, after running their long term experiment (daytime running lights) found that the accident rate went down. They've even been trying to get the U.S. to require them, but sadly, without any luck.
  13. mboileau
    mboileau New Member
    278
    SF Bay Area
    I disagree with the earlier statements that automatic headlights require DRL. I just switched from my 2002 Jaguar X-TYpe which did have auto headlights and did NOT have DRL. I just left the selector knob in the Auto position all the time and never had to think about it. They had a mind of their own and worked great. I especially appreciated it driving through a tunnel back and forth to work each day.
  14. 04prius
    04prius New Member
    35
    San Diego, CA.
    The headlights will turn off upon opening of the driver door. :idea:
  15. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    If you have the HID headlights, I would advise against always driving with your lights on - while it could be an old wive's tale like the bulb on a plasma TV burning out quickly (not true), the HID lamps have a much more expensive replacement cost than standard halogen lamps and if you overuse them and burn one out it's not like you can just swap in some halogens (different voltage and whatnot).
  16. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Safety not withstanding, I was wondering how much more the ICE has to run, say in a 1 year period, to keep the 12V battery up if you have DRL or turn on your headlights yourself. Seems a good way to slightly decrease you mileage :)
  17. 04prius
    04prius New Member
    35
    San Diego, CA.
    The 12v aux. batt. is charged by a DC to DC converter in the inverter.
    The power to charge it comes directly from the high voltage batt. So the engine dosen't need to run to charge it like other vehicles(alternator). If you look colsely the only belt driven accessory on the 04 is the water pump. :D
  18. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    True, but look at this way: the cost of replacing a lightbulb, I imagine, is a fraction of what it would cost to replace an entire fender after an accident. Given the scarcity of Prii, I wonder if there's enough of a parts reserve at dealerships to cover replacement parts? Dianne?
    p.s. what DOES a replacement bulb for HID lights cost?
  19. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    i'm back.... been busy with a new Golden Retriever puppy......
    if one horsepower = about 750 watts, you'll find that running any lights at all, or all of them, or none of them would make a difference of a few tenths of a mile per gallon for a regular car. all things considered, it might be worth 1/2 mpg [my WAG, not even SWAG], and if 0.5 mpg is important to you, turn off the DRLs....
    on the other hand, amortizing the cost of the accident that's prevented by running your DRLs would smother any advantage in mpg's unless you're competing for a local record... :)
    in fact, for most cars, the better [lower] air resistance from closing your windows at speed more than pays back the load on the engine from the a/c ! think about it: the open window acts like a scoop, picking up relatively static air outside the car and quickly accelerating it up to the car's speed. THAT takes a bunch of energy, hour after hour.
    roll up the windows, turn the lights on, and enjoy!
    +af
  20. Ken Cooper
    339
    <div class='quotetop'>QUOTE(\"AdminCoop\")</div>
    Danny, let me counter this comment with some advice for you. I would advise that you always drive with your lights ON. The cost of a headlight, whatever the cost, is a small price to pay for yet another safety feature.
    Ken
