Automtic Door Lock Settings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by stephen p. merry, Nov 25, 2014.
  1. stephen p. merry
    stephen p. merry New Member
    New Gloucester Maine
    I am trying to change the automatic door lock setting to unlock the doors when I open the drivers side door not when I shift into park. The manual is vague and I am not having any success at all. Any help?
    49,455
    it is vague, and a bit tricky. if you can't pull it off, the dealer can do it for you, or it can be done with a code reader.
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Use the Nav or display radio. There is a GUI for it now. Hit the SETUP button then go into door settings. The car must be in ON or READY for this to work. Since I have a Five the exact menus are different but the gist is the same.
    I did the same thing. Didn't want to be mugged waiting at the bank drive thru with the car in Park.
