Autostart Doesn't Manage Temps & Ice properly
Discussion in 'Prius v Technical Discussion' started by jimerb, Dec 3, 2017.
  1. jimerb
    jimerb Junior Member
    NY
    2013 Prius v wagon
    I have a 2013 Prius V and when I autostart it, the car doesn't auto adjust the temperature.
    So for example, If I turn the defrosters on before I leave the car (front and rear), if i autostart it goes off. If I leave the heat on with the defroster on the front windows it will remember that. If i forget there is no automatic adjustment.
    Is there a hack or something that let's you configure how the autostart behaves?
    Are there any settings or wiring I can check?
    Thanks.
    49,490
    welcome!
    that is normal. you have to remember to set it up before exiting the car. unfortunately, the front and rear defrosters reset, every time you shut the car off.
