Aux Battery Prophylactic Replacement?
Discussion in 'Gen 2 Prius Main Forum' started by Bluesman78, Mar 16, 2017.
  1. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    2006 with 93,000 miles.
    Battery was last replaced in the dealer 1-8-2013 at 66,000 miles. The reason it was replaced was because it had to be jumped.
    Can someone recommend a good time/mileage to replace the battery so I don't need to get a jump. I don't really see myself testing the battery myself, so i'd rather just stick to a scheduled replacement.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    I am going on 3 years with my replacement Optima yellow Top.
    Invest in a battery charger. One with a charging meter that shows current draw. Once a month throw it on the charger and observe its charging behavior using the 2 amp mode. Really the best way to test a battery over years. Its super easy using the front jump points take 1 minute to hook it up.
    This monthly maintenance charge will add years to its life. But over time you will see that it will begin struggling to achieve a full charge.
    It begins to take much much longer to achieve a full charge. Then you know it getting tired and time to replace.
    No drama it will give you plenty of notice.
    I got 7 years out of the original battery since I bought the car new. My observations convinces me that the factory battery may be superior to the Optima based on there charging behavior. Its a little more expensive than an Optima.
    m.wynn likes this.
  3. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    Thanks Ed - can you recommend a model/make from Amazon or Autozone? Thanks! I don't have a garage (city kid parking on the street, so a little bit challenging to charge, but I can figure out a way to do it)
    49,482
    can't give you a hard date. some say 4-5 years. the issue is whether you have ever run it down, or if you don't drive very frequently. other than that, they are good for 8-10 years.
    my 5 year old battery still measures 12.8 volts, and i leave it in the cold for 5 weeks every winter.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Given your circumstances, a mulit-meter might be a better use of your money than a charger.
    IF......the car is used regularly, that is driven at least 3 days a week for 10 miles or more to keep the battery charged then it likely will last 5 years or more.
    Measuring the voltage after it sits overnight will give you a rough indication of it's health.
    Stevewoods and Bluesman78 like this.
  6. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Can't go wrong owning a dvm. Buy a nice $75 Fluke on eBay. It will work forever. But nothing beats comparing its slow charge rate over a few years as it ages..
    Not being able to charge it in a garage is a hardship.
    I like this one as it has 2 amp mode and its very simple. My Optima over 3 years of maintenance charges is now struggling to charge to 100% full after 12 hours. In 2 amp mode which is the best mode to charge in takes quite a few hours to charge from say 13. to 13.8. It did it when it was brand new. It would illuminate the FULL light. Takes forever now to light that FULL light only 3 years so it's showing minor signs of wear.
    The factory battery that came with the car showed better signs of charging at that age.
    A DVM will not show you that.
    My oem factory battery started to suddenly show it was having a problem charging up. Very noticeable on the charger. I replaced it immediately.
    Edit:
    For some reason it wont load my Amazon.com link. But on amazon search Schumacher SE-520ma.
    Simple easy charger will last 30 years. $50.
    #6 edthefox5, Mar 18, 2017
  7. Stevewoods
    Stevewoods Senior Member
    648
    993
    Seattle, WA
    Considering your parking situation, etc. I would agree with Sam Spade's suggestion of just keeping an eye on the battery, by using a multimeter (volt meter) testing at the jump point under the hood.
    Depending how paranoid you are, maybe test once-a-month or a few times a month, first thing in the morning after the car has sat overnight (a Saturday or Sunday morning, if you have weekends free).
    If it reads under 12.2, replace. The battery should last at least five years, though. This meter is sold for under $20 USD at both Home Depot and Amazon.
    Dawson Tools DDM422 Compact Digital Multimeter with LCD Display Back Light
    I have a Klein tools brand I bought for around $40 that works well. Even have an old Craftsman Analog...
  8. Mendel Leisk
    38,723
    I'd second getting a decent multimeter. It's what I use the most. Still, for when your battery is getting suspect, a digital load tester is the bee's knees:
    I'd also get a good smart charger (around $70~80).
  9. bisco
    49,482
    price out a replacement battery, it might make your decision easier.
  10. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    July 2011 I put the Yellow Top Optima batt in there...no problems but maybe I should update
    The OEM batt has lasted many years for some...depends if you've run it down in its history.
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    WAY overkill, Ed.
    A $10 meter from WalMart or Lowes.......or even a free one from Harbor Freight is all the average owner needs.
    kenoarto likes this.
  12. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Get what u pay for.
  13. Sam Spade
    2,036
    1,023
    2017 Prius c
    Give it a rest, Ed.
    Sometimes you take a general rule and carry it WAY too far.
    In this case, anything that will read 12 V and will show if it is higher or lower than the last time you checked it will do nicely in about 95% of the cases. Even a test lamp glowing bright or dim can do in a pinch.
    Do you pull your trailer with a $100,000 Hummer ?
    Why not......you get what you pay for, after all.
  14. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Wow
  15. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I tried replacing my 12V battery with a condom, but it didn't work. ;)
    Ok seriously though, my OEM 12V battery lasted 7.5 years and its replacement is at 5 years so far with and no sign of weakness yet.
    The 12V battery doesn't get pushed very hard in the Prius so it can last a long time, especially if you've never let it go flat. Personally, as long as my battery tests ok I'm happy to keep on using it. When it starts showing too much signs of weakening I'll replace it. My original battery faded out pretty slowly, with measured voltages in "Ignition on" mode gradually dropping from 12.0V down to about 11.5V over a period of months.
  16. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    Replace the battery every. Four or five years and no need to worry.
  17. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
    I found a dealer coupon to replace the battery for $110 so I'm just going to do that since i'm on 4.5 years and about take a 1000 mile road trip, don't want to have a problem and certainly don't want to worry too much about it. Last battery test was OK when I had my my oil changed at the dealer (with a coupon and free multi-point inspection). Thanks for everyone's input.
    [Edited, price was $110, not $105]
    #17 Bluesman78, Jul 2, 2017
  18. bisco
    49,482
    that's an incredible price, congrats!(y)
  19. Bluesman78
    Bluesman78 Member
    162
    46
    Boston
  20. bisco
    49,482
    call first. i've asked about battery specials before, 'oh no, not for a prius!'. but the ad says 'fits all toyotas.':p
