AUX Port and MP3 Player Question
Discussion in 'Gen 2 Prius Main Forum' started by prius2006rocks, Dec 15, 2005.
  1. prius2006rocks
    prius2006rocks New Member
    159
    CA - Central Valley
    I can't wait to get my 06' Prius! For those that already have an 06'or are familiar with the AUX port in the center console, I was wondering how I would connect my new Ipod to the car. What type of cord do you need - one with speaker jack connectors on both ends? If so, where do you find that? I had trouble tracking one down. Thanks so much! :)
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Yes, you need a double ended hadphone jack. They should be easy to find. try your local Radio Shack. Just ask. If they don't have them in stock they will likely be able to order you one.
  3. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I got one right before I picked up my car. I had it at the dealer and the saleman asked what that was for...my ipod of course.
  4. prius2006rocks
    159
    CA - Central Valley
    Thanks everyone!!! :)
  5. deh2k
    deh2k New Member
    241
    New Hampshire
    I recommend something like this:
    Auto Kit for iPod w/ Dock Connector
    It has two advantages over the plain headphone jack adaptor. It will power the iPod so you'll never run out of juice. It also connects to the line-out of the iPod which has higher fidelity and is not affected by its volume setting.
  6. deh2k
    deh2k New Member
    241
    New Hampshire
    I forgot to mention that you'll still need that same male-to-male 1/8" stereo audio cable.
  7. DocVijay
    1,455
    Tampa, FL
    I agree, this is a better option for connecting the iPod. I believe the 2006 still has the 12V socket in there too, so no wires dangling out anywhere.
    ...and yes, the same cable we discussed is still needed, so you could just get the Belkin part later.
  8. asyvertsen
    asyvertsen New Member
    www.sik.com
    they sell a cable called the imp. This plugs into the port in the bottom of your ipod. You still need the same double male end headphone cable but you don't have to go through the ipod amplifier. This cable also comes with the a charger-- so you can play and charge you ipod. I highly recommend it-- you will probably notice better sound quality too.
