Auxilary battery voltage? Does the Prius do 2 stage charging?
Discussion in 'Gen 3 Prius Technical Discussion' started by Jerry Liebler, Feb 18, 2017.
  1. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    This is a long story but I'll try to shorten it. My 100 % recycled 2012 PIP was totaled by being "T Boned" by an inattentive driver. The other driver's insurance paid for my replacement, a 2013 PIP with a few less miles and no damage history. On the drive home in the replacement I used way more gas than I was used to, about 100 less miles per tank. I started searching for the cause. First I Installed the lower grill block next I changed the oil and air filter then I replaced the snow tires with Bridgestone EP422+ inflated to sidewall limit of 51PSI, then I found dragging, badly worn brakes and replaced them these changes helped a little but something was still very wrong. I replaced the dying but not dead 12 volt battery with 40 AH of LIFEPO4 and continued my search for a possible cause. I'm very sure that I finally found the culprit based on trip odometer data over several short trips after I cleaned the mass air flow sensor. I run the Android application "TORQUE" through an OBD -Bluetooth adapter and look at several interesting things, among them the 12 volt system voltage which I kind of assumed was always 14.4 volts whenever the car is "running". But with the new 12 volt battery I'm seeing something I've never seen before, When I first turn on the car the voltage will be 14.4 but after some running, in the daytime, it will drop to 13.3 but turning on the headlights will move it back to 14.4. My interpretation of this observation is, Toyota has implemented a form of 2 stage charging for the auxiliary battery. The 2 stage charging algorithm is something like, hold 14.4 volts until the charging current falls below set-point 1, then drop the voltage to 13.3 (float) until the charging current exceeds set-point 2 which resets the 14.4 volt system voltage. Has anyone else observed this? Can anyone verify the 2 stage charging?
    Simtronic likes this.
    49,371
    no idea, but it makes sense i guess. i would think amperage would be more important though?
  3. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    I don't know about the 2-stage charging, but my aux. battery in a non-pip does the same: 14.4 in the beginning (if it's really cold even higher), 13.5 after a while of driving (if the outside temperature is not too low) /
  4. kc410
    kc410 Active Member
    262
    250
    2010 Prius IV
    My non-PiP does drop the 12V batt float voltage to ~13.4V, but only if certain conditions are met:
    1) the engine must be warmed up enough to shut off when stopped.
    2) the transmission must be in Drive.
    3) the AC must be off.
    4) the lights must be off.
    When (& only when) these 4 things are satisfied, will the float voltage drop to ~13.4V.
    Otherwise the battery floats at ~14.4V.
    Watching Torque I knew that the voltage would often drop to 13.4V, but had never tried to document under what conditions it would happen. This morning I watched it closely & came up with the above results.
    #4 kc410, Feb 20, 2017
  5. mrbigh
    3,686
    699
    Long Island, NY
    Upon my experience and observations.........
    I think that the 14.4 VDC argument is when the Hybrid System "Inverter" is in operation.
    If not, the 13.8/13.4 VDC would be the AUX battery float voltage with no accessories sucking any juice.
