Auxiliary battery 12 volt with 28Ah
Discussion in 'Gen 3 Prius Audio and Electronics' started by Hasib, Dec 8, 2023.
  1. Hasib
    Hasib New Member
    Kabul
    Hello I hope everyone is doing well,
    I have Prius 2010 model, sometimes my prius become wild like it’s not going in ready mode the dashboard says: “Auxiliary battery
    (For starting) Insufficient charge Please check the instruction manual” even though the lights are not dim but after to three attempts my speedometer become blurry and weak also my internal lights and one side of the speedometer which shows traction battery become blank and after some time it came back.
    but when I unplug the positive terminal from 12 volt battery after 2 or 3 times attempting it finally works (ready mode). Is that a problem of 12 volt battery? If it is so why when I unplug the auxiliary battery and sit for 5 minutes then I plug back after 2 or 3 attempts it finally get In ready mode? My auxiliary battery is 28 Ah. Some people told me that it’s getting winter and cold the battery is old and you need to replace it. For example last night I was on a wedding party and I parked the car in open parking it did the same thing then I unplugged the 12 v battery terminal and sit for few minutes then plug it back and got in ready mode. But when I came back to my apartment and my parking is in underground of the building and when Woke up in the morning it get in ready mode probably my parking is warm I have no idea. Do you guys think it’s my 12 v battery? Any advise is appreciated
    Thanks…
  2. BiomedO1
    BiomedO1 Senior Member
    1,434
    782
    SacTown, Ca
    Borderline battery, and/or loose battery connections, and/or parasitic draw.
    You'll need to test to figure out and start eliminating the issues above. First, stop disconnecting the battery! Clean, reconnect and ensure a good connection to the battery. Get a jump-box and use the jump points under the hood. That AGM battery is more than likely dried out and on it's last leg. Disconnecting the battery allows it to regenerate enough to close those traction battery relays. Once those relays are closed the aux. battery just sits there and is recharging - if the battery is bad, it can't recharge enough to restart again.
    Hope this helps...
    ASRDogman and Brian1954 like this.
    49,358
    is the battery 2010?
  4. Mendel Leisk
    38,634
    That's the spec? How did that come to be, unorthodox replacement? IIRC stock battery amp hours is a bit over 40.
    Kabul, Afghanistan?
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,913
    4,676
    Texas Hill Country
    Weak battery floating up when disconnected. About as borderline as possible.
    Brian1954 likes this.
  6. Hasib
    Hasib New Member
    Kabul
    Yes Afghanistan sir
    Today I bought an acid battery for my prius with 60 Ah, will it work fine? Because I couldn’t find any AGM battery in my market. So I must replace it with Acid battery. I hope it will not damage my car.
    Thank you
    Today i bought acid battery with 60 ah with small in size it fitted perfectly, I searched every shop for AGM battery but I couldn’t find it so I must replace it with acid battery and the air tube can not fit in it so I left it on the floor of the car. Well the battery explodes if I don’t put the tube. Well it give me at least 4 years lifetime or 3? I don’t know what to do.
    #6 Hasib, Dec 9, 2023
  7. Mendel Leisk
    38,634
    You’re not the first to put a lead acid battery in. The battery will vent hydrogen into cabin, arguably minuscule amounts. How much i don’t know; I’m out of my depth. Also, in a severe crash, there’s danger from acid spill. Again, how much danger is arguable.
    I would just carry on, but research AGM battery availability, for future.
  8. BiomedO1
    1,434
    782
    SacTown, Ca
    LoL, don't smoke in the car. No, it shouldn't explode - if it's a halfway decent battery. TAKE MY FIRST SENTENCE SERIOUSLY. Your occupation states that your a pilot, so you know the dangers of H2 or contaminates venting into a tight enclosed space. Air exchange is the key and it may speed up internal oxidation within the passenger cabin.
    Your an adult - just be mindful of the safety concerns...
    #8 BiomedO1, Dec 10, 2023
  9. Hasib
    Hasib New Member
    Kabul
    Hello everyone
    I hope this reply finds you guys well, we all knows that it’s winter time, and the weather is getting cold day by day, I have an issue with cold start when I am trying to start my prius in the morning my engine is knocking and shaking for few seconds like 3 or 5 seconds after that it become normal but the knocking and shaking is very scary but in some mornings the knocking doesn’t exist but sometimes in the morning it’s knocking and some times the knocking sound is very low and for a short period of time. I asked one of my neighbor who has prius and he said it’s normal because you are not using your prius car everyday I usually use my car once or twice a week. So is that normal for prius cars to knock and shake in winter??? I am using (SP 0W/20) genuine Toyota motor oil. Any advice is appreciated.
  10. Hasib
    Hasib New Member
    Kabul
    Hello everyone
  11. bisco
    49,358
    hello!
    2010 is notorious for a blown head gasket, starting with a very small leak that gets larger over time.
    however, it is also possible that you are experiencing the cold startup shakes where unburned hydrocarbons for the last cycle remain in the manifold.
    always make sure the car is fully warmed up, and engine off before shutting down the last time of the day.
    there is an updated manifold, but idk if it helps any, or if it is available in afghanistan.
    all the best!
    BiomedO1 likes this.
  12. BiomedO1
    1,434
    782
    SacTown, Ca
    Keep an eye on your engine coolant levels; the coolant tank hanging on the fender - NOT the one hanging on the radiator. If the coolant levels are slowly going down with no visible leaks; you'll need to test for head gasket integrity (compression & leak down test). Use a marker or tape, a slow leak could take a few weeks to a month for the levels to change, where it's noticeable.
    Have your friend do the same, as bisco stated - these model years are know to blow head gaskets.
    Hope this helps....
  13. Hasib
    Hasib New Member
    Kabul
    Thank you for reply, if check it on OBD2 will it give a code?
  14. bisco
    49,358
    I don’t think there’s a code for the head gasket, it’s a fairly complicated test
  15. Mendel Leisk
    38,634
    Once it’s really gone you’ll get P03XX, with XX sub’d by 00 through 04. 00 being general misfire, and 01 through 04 being cylinders with misfire. It’s typically 00 and 01.
    also could be P0401, EGR flow reduction.
    but usually after the head gasket is already leaking coolant.
  16. BiomedO1
    1,434
    782
    SacTown, Ca
    IMHO, When you catch this stuff early and take care of if it; BEFORE the computer starts throwing codes - the less likely you'll damage other parts of the engine (ie. bent rods, hole in the side of your engine, warped heads). The repair will also be cheaper; though labor cost over there is pretty inexpensive - it's quality of parts and availability that's the problem on your side of the pond.
    Hope this helps....
  17. Mendel Leisk
    38,634
    And if you want avoid this stuff happening, clean the full EGR circuit, every 50k.
    nobody buying these cars, back in 2010~2015, saw this bs coming, but here we are.
    and Toyota doesn’t want to know about it, so apart from a few shops that know what they’re doing, it’s DIY.
  18. rjparker
    7,913
    4,676
    Texas Hill Country
    You have a blown head gasket but on this car it does not 1) make the oil milky 2) show up on a coolant combustion gas test 3) cause the coolant to drop for months or 4) throw misfire codes because it initially clears quickly.
    It is a big problem because it can bend piston rods, blow holes in the block, ruin the engine damper and eventually months later cause the engine to overheat.
    Most diy’ers and mechanics will throw much money into it with new plugs, coils and injectors plus clean or replace egr coolers without success although new plugs often give you a week or two of good starts.
    A quality borescope inspection in the hands of an experienced person can often see a steam cleaned piston.
    If it’s already burning oil as well (common on these engines) a rebuilt replacement engine with revised pistons and rings is the longterm solution, which of course includes new gaskets.
  19. Hasib
    Hasib New Member
    Kabul
    Thank you for your replies, I don’t have any above symptoms of blown head gasket except the knock and shaking in cold start. I will change the headgasket soon.
  20. Hasib
    Hasib New Member
    Kabul
    Hello i hope you guys are doing well, today I bought a new 12v battery and I have seen there is a white thing alittle bit deap stuck to the vent hole of 12v battery. It’s impossible to reach with your fingers to that white thing. Shall I remove that white thing from vent hole or it’s default? I don’t know what to do about it. Its acid battery. thank you in advance. I asked it from dealership he said I don’t know and he was not sure wether to remove or leave that white thing. I bought it for my Toyota corolla 2006.
