Auxiliary Battery Maintenance and Cover Removal - Warning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bonneville52, Nov 29, 2004.
  1. Bonneville52
    Bonneville52 New Member
    Oak Creek, Wisconsin
    2004/2005 Prius
    Over time the positive terminal of the auxiliary battery and its associated terminal clamp/nuts/bolts will most likely become corroded and will need to be cleaned with baking soda. Given to its location this could prove to be a bit of a mess.
    It's with this in mind that I wanted to coat the terminal(s) with a protective coating to aid in preventing the corrosion ... there are commercially available sprays made for this purpose. Trying to remove the terminal clamp nuts and bolts, and the terminal clamp isn't an easy task when they are covered with corrosion ... and applying a wrench in this area doesn't appear easy under the best of conditions.
    Unless your dealer 'doped' the terminal(s) ... and that's not likely ... you may want to look into doing this as it will save you a lot of grief later. I didn't actually 'spray' the terminal(s) as spraying them will also make a mess of the battery area. Instead, I sprayed the protective coating into a small container and then painted it on the terminals with a small brush.
    You don't need to remove the terminal clamps to do this. Just coat them as they stand. I've used this material on my other cars with great success. You'll need a small ... very small ... common screwdriver to remove the red cover from the positive battery terminal. It's held in place by three plastic clips as well and you'll need to lift the clips off the retaining pins.
    NOW THEN ......
    According to the owners manual, to access the auxiliary battery, the battery cover (carpeted cover) can be removed by 'lifting it'. There isn't much about this other than an illustration and an arrow pointing 'UP'. Easy enough ... just lift the cover up, right? Nope ... there's more to it than that. The cover is held in place by plastic retaining clips that are molded onto the cover and these will break if you just 'lift' the cover. I found that to remove the cover, I had to press it down 'slightly' while pressing the the surrounding liner 'outward' and then carefully manuver it out of the slots. In any event, I had to shift it around a bit before I could remove it. (See photos for location of battery cover retaining clips).
    I hope this information and the photos prove helpful.
    Bob
    Oak Creek, WI
  2. onerpm
    onerpm New Member
    477
    MN
    Re: Auxiliary Battery Maintenance and Cover Removal - Warnin
    dang! nice job! can we hire you to retranslate/rewrite the owner's and NAV manuals?
    rob
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Yep, great job illustrating.
    With the location of the battery on the interior of the car, do you still believe that it will succumb to rust and corrosion as much as a regular car's battery?
  4. Bonneville52
    Thank you for the compliment ... it's appreciated.
    Actually, the corrosive buildup on the battery terminals is more likely to occur before that of the area it's stored in ... provided of course that the electrolyte from the battery isn't spilled in that area. It's nasty stuff.
    The following site has more information/photos on this.
    Different automobile but the principle is the same.
    Just click on the photos for a larger view.
    Needless to say, there are a number of sites that cover the science, cause, and effect of this subject. :)
    http://focus.noegruts.com/battery/battery.htm
    Bob
  5. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The prius battery should not corrode like that. If it does, that should be covered under the warranty. The battery in the Prius is designed to vent to the outside of the vehicle, and has other designing to minimize the chance of acid leak, even in minute amounts, around the battery.
    A small battery acid leak, or acidic gas exposure in the engine compartment is not a terrible thing. Even if the battery tray were exposed and damaged, that's not nearly as bad as exposing your cargo area to acid exposure. Toyota knew this, and used a battery design that would not allow acid or gas into the passenger/cargo compartment.
    therefore, the battery terminal also should not be exposed. If it does, I would submit this for warranty repair.
