Auxiliary RCA Inputs
Discussion in 'Gen 2 Prius Audio and Electronics' started by seanyob, Jul 26, 2006.
  1. seanyob
    seanyob New Member
    I've been searching the web for an auxiliary input adapter that includes both audio and video. After seeing the CoastalTech Ultimate IPod, I got interested into doing literally the same thing, through a cheapier solution. What it sounds like is that you buy the Ultimate Lockpick for $230, and this gives you rca connections. Then you buy the Valor iLink system for $120 and connect it to these rca connections. My problem is, I can't justify spending $230, almost twice as much as the iLink, for what is basically an adapter. I do not need any of the functions of the lockpick. Anyone have a hopefully cheap solution to this problem?
