Auxilllary Outlet Override?
Discussion in 'Gen 2 Prius Main Forum' started by Swingshiftworker, Jul 10, 2006.
  1. Swingshiftworker
    Swingshiftworker Junior Member
    97
    San Francisco
    I was trying to charge my phone after having already parked the Prius and learned from the manual that the auxillary outlets that you use for that purpose will only power up w/the Prius in ACC or IGN-ON.
    Is there any way (other than hot wiring them) to power these outlets while the Prius is powered off? Please advise. Thanks!
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    One of these days I'll document how the separate power switch for my
    instrument panel also kicks the PWR OUTLET FR relay coil and enables
    the dash outlet, but the wire to cut and insert a diode into is a
    bit hard to find. But you could just do the always-on mod on the
    high-current side which is more accessible...
    _H*
  3. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    Well, there is no quick fix for your question. Either way, you will have to do some wiring.
    Here are a few ways:
    Darelldd's Prius Mods (follow the link, click on Prius, click on mods) - adds an additional always on outlet
    Darell's page
    or
    Coastal's mod - converts your existing outlet to always on
    Power outlet mod
  4. Swingshiftworker
    97
    San Francisco
    <div class='quotetop'>QUOTE(mssmith95 @ Jul 10 2006, 01:25 AM) [snapback]283705[/snapback]</div>
    Thanks! The Coastal mod is exactly what I'm looking for. :D
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Swingshiftworker @ Jul 10 2006, 05:59 PM) [snapback]284175[/snapback]</div>
    You'll notice that the instructions for the Coastal mod is on their site. You can buy the parts locally and install it that way.
  6. Orf
    Orf New Member
    414
    Devonport, Tasmania
    The Australian 06 Prius does not have a power outlet in the dash, only one in the centre arm rest. Where abouts is the US one located?
  7. marjam
    marjam Member
    220
    Silver Spring, MD
    <div class='quotetop'>QUOTE(aaf709 @ Jul 10 2006, 09:51 PM) [snapback]284192[/snapback]</div>
    It is under and to the left of the lower glove box.
  8. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Orf @ Jul 10 2006, 08:00 PM) [snapback]284245[/snapback]</div>
    It is the one on the right here, and does not include the switch.
    The other one was added.
  9. jrmgkia
    jrmgkia Wish I was cycling
    53
    Campbell, CA
    I know my mod isn't the best solution, but it was really easy (10 minutes). And at the time there wasn't any other fix for this problem. I listed some of the downsides to this mod but it has worked great for the last 2 years. On our newer 2006 Prius I did the Coastal Tech mod, but I just bought the parts at Napa and did it on my own.
    Link to my website: http://www.law2.byu.edu/millerj/cars/2004priuspowermod.htm
  10. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(darelldd @ Jul 11 2006, 12:12 AM) [snapback]284319[/snapback]</div>
    Nope, my Aussie 06 does not have that power outlet.
  11. Zamboni68
    Zamboni68 New Member
    Lancaster, Ohio, USA
    With my two cell phones, wireless PDA, Bluetooth headset, etc. the one outlet under the dash and the hard-to-use one in the console weren't enough...so I added two always on 12V outlets (bought them from Radio Shack) and powered the outlets with a mini-fuse add-a-circuit from AutoZone (10A fused, 2A in the "dummy" slot) into an empty slot in the fuse panel under the dash.
    Works well, looks OEM. Total cost: $15
    [attachmentid=7379][attachmentid=7380]
  12. Zamboni68
    Feel free to conatct me if you are planning on undertaking this modification before you begin. I want to save you time/frustration that I had to trouble-shoot.
  13. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Zamboni68 @ Jul 12 2006, 08:27 PM) [snapback]285425[/snapback]</div>
    From -
    Those outlets are from RS? They look exactly like mine! Not sure where mine is from though - it is out of my "automotive junk" drawer. Good to know where I can get matching ones.
    *removed... found my problem!*
    Oh... and where did you purchase the "Add-a-circuit" that'll fit the Prius? I bought some of those long ago directly from the mfg... but I haven't seen them in stores.
  14. McShemp
    McShemp New Member
    371
    SA, TX
    <div class='quotetop'>QUOTE(Zamboni68 @ Jul 12 2006, 10:27 PM) [snapback]285425[/snapback]</div>
    Was it just trial and error to find an always-on, empty fuse slot - for the power tap - in the fuse block?
    With the Coastal mod, is the outlet shown (under the dash) on the same fuse as the green wire? So there's a relay somewhere between the fuse block (green wire) and the factory outlet (solid white wire)?
  15. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(McShemp @ Jul 31 2006, 11:09 AM) [snapback]295211[/snapback]</div>
    That's how I did it. There are a few always hot, that are unused. Just use a lighted test probe with one end grounded.
    Yup. The relay passes the power from the green wire into the outlets when the ignition is on. Tapping into that green wire before the relay uses the same circuit (and fuse - just bypasses the ig-on relay) to make it always hot.
  16. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< Just bear in mind that the 12v auxiliary battery is about the size of a motorcycle battery and can be easily depleted. One reason the auxiliary outlets are disabled in a power off situation is to avoid depleting this battery, which can prevent closing the relays which connect the traction (big) battery and require a "jump" to start the Prius. This procedure risks damaging the sensitive electronic elements of the Prius, especially if the jump polarity is accidentally reversed. There's also the Warranty issue when modifying the Prius design.
    Is charging a cellphone with the Prius "off" worth the possible risks? For our cellphones, I purchased extra batteries and a desktop travel charger and when driving keep an extra charged battery in the car.
  17. McShemp
    McShemp New Member
    371
    SA, TX
    <div class='quotetop'>QUOTE(Charles Suitt @ Jul 31 2006, 02:43 PM) [snapback]295259[/snapback]</div>
    I know ... I know ... but I do like the idea of a small, 1.2W solar panel trickle charging through the 12V outlet to keep the battery topped off. That's why I'd like this mod.
  18. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Charles Suitt @ Jul 31 2006, 12:43 PM) [snapback]295259[/snapback]</div>
    Warranty? What warranty?
