Average battery life
Discussion in 'Prius c Main Forum' started by Yoda1nzfxe, Jan 25, 2018.
  1. Yoda1nzfxe
    Yoda1nzfxe Junior Member
    About how long does the high voltage battery last? I’m use my car mostly on local roads so the electrons are being used as designed. As opposed to someone who is just driving on the highway. In that case I can see how battery life would be diminished. Just out of curiosity will it last til 200k miles. That would be awesome. If not maybe i need to save some money for a replacement battery. I love my car and do not wanna part with it even if it means replacing the battery. Please respond quickly as my attention span is would is more goldfish than human
    52,386
    i believe it is designed to last between 150 and 200,000 miles. if nj is a carb state, you have a 10/150 warranty. otherwise, it is 8/100.
    unfortunately, each battery is not 'average', and it is always a good idea to have a small nest egg for out of warranty repairs, be it for the battery, or any other expensive prius system.
  3. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    My thought is 10yrs and mileage does not matters as long as driven regularly. If you live somewhere hot you might not make it 10yrs.
    With that said my previous 2005 Prius is at 248k miles and still running original battery. Gets 46mpg avg still too.
    iPhone ? Pro
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    It's a combination of age and mileage.
    Here is likely a bell curve of when failures occur.
    Let's assume car is driven regularly and an average number of miles is driven. (no snowbirds leaving their aging car sitting for months unused in a cold garage. No taxicabs that run 18 hours a day)
    Making it to 200k or beyond without a pack failure may be possible, but not the norm.
    Between 150k and 225 it would be likely that you would need to deal with the battery. About a $2,500 proposition.
    If yours last longer great. But I wouldn't bet the farm in it.
    A hybrid is t necessarily going to save you any money, but you certainly will lower your overall consumption of gas and pollution emitted.
    Raytheeagle likes this.
  5. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Mines gave in at 120k miles.
  6. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    So your 2013 Prius C hybrid battery failed at 120,000 miles?
  7. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Yup.
  8. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    You are definitely on the early/lower mileage end of failures.
    Thanks for the data point.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If you want an Average, you need to ask again in at least 10 years.
  10. padroo
    padroo Senior Member
    2,763
    2,252
    I read somewhere that the battery was designed to last the lifetime of the car whatever that means. I guess if he battery goes bad and you junk it then that is the lifetime of the car. It is what it is.
  11. Deft Jef
    Deft Jef Junior Member
    27
    Chicago
    Battery life will be more dependent on years as opposed to mileage. 12-15 years on average, which will be dependent on a variety of factors such as climate, mileage, if the car not driven for extended periods, etc. I've seen high mileage older cars (2004 w/300,000 miles) on the original battery and the same model year car with only 90,000 requiring battery replacement.
    #11 Deft Jef, Jan 26, 2018
  12. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    That's what will happen to me. That HV battery dies, I'm towing it to my sons house where it will be disassembled slowly. I'm not spending that kinda cash to keep a car rolling.
    There's an individual who just posted this week in the "C" forums. HV battery dead at 101k...
    #12 dubit, Jan 27, 2018
  13. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    $2,000 is too much?
  14. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    For me yes, I'm not messing with it. It's a car, not a family member. Got a son and a brother who are both Master techs. (Honda/GM) So when it dies, I'm going with something my son or brother can work on. Well, I should just say Honda because there is no way I'd ever buy a GM product.
    If I had to spend $2000 on a car repair, I'd buy a cheap a** civic for $1000 off my son and drive it for 80k miles.
  15. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I believe the Prius C only comes with a 10 year 100k traction battery warranty even in carb states.
    Are the individual battery modules the same as a non C / non plugin 3rd generation Prius?
  16. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    No, it's 8 year / 100,000 in non carb states. Just looked at the warranty booklet...
  17. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Is it longer in carb states?
  18. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    That’s a record.
  19. cv66-200traps
    cv66-200traps New Member
    INDIANAPOLIS
    I read somewhere that the actual battery life is unknown, because it is much more likely that the car will be totaled. There are many cases that document prius' lasting over 300K miles. As for cost, a "battery pack failure" is virtually non-existent. The "battery" is actually made up of 28 cells which are independently replaceable. I am on my second prius (first one lost when I was hit making a left turn). My used car dealer, at Savy Motors in Alpharetta, GA told me that if there is a battery failure, most of the time it is due to one or more of the cells doing bad. If so, he can put in a refurbished cell for under $50, plus a diagnostic fee to locate the failed cell(s). So, you can possibly have it repaired for under $200!
  20. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    I bought a used HV battery that had 29k miles on it and been good ever since.
