Avg mile per gallon on the display dashboard
Discussion in 'Gen 3 Prius Main Forum' started by Weezie25, Oct 24, 2012.
  1. Weezie25
    Weezie25 Junior Member
    Hi was trying to familiarize myself with the buttons on my 2012 prius the night before and noticed that the "Avg mile per gallon" is no longer on the display dashboard the next day... i tried to re-trace the thing i did but unsuccessful.. Can someone advice? Thanks
    51,155
    what trip are you displaying? A, B, ODO?
  3. Weezie25
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    You need to cycle through the 'Display' button on the steering wheel to get back to the screen with the mpg info..
  5. Weezie25
    Thanks for the pic ny_rob... see instead of "CONS." the displays says "GAS PRICES"... i did cycle through the 'Display on the steering wheel but don't know what option to change...
  6. bisco
    51,155
    okay, you're in a programming mode where you input gas price. we don't have that on pip, not sure how to get out.
  7. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Go into your display settings and there's an option for CONS.
  8. Selzier
    Selzier Whee!
    148
    51
    Cycle through "DSPLY" on your steering wheel controls until your MFD displays "settings" along with the date. Now press and hold "DSPLY" until you can adjust your settings. From there there should be a few options for you and pressing and holding "DSPLY" takes you into each submenu. Quickly pressing either "DSPLY" or the one below it (I can't look at my car right now so I don't know what it's called) will cycle through your current options.
    From there you can find the option to change from Gas Price to Cons.
