avg mpg accurate, single drives not so much
Discussion in 'Gen 4 Prius Fuel Economy' started by nema32, Aug 20, 2022.
Tags:
  1. nema32
    nema32 New Member
    Albuquerque NM
    2022 Prius
    I'm trying to understand why my avg mpg is correct (verified by odometer / gal), but individual drives aren't.
    I'm getting 76.0 avg mpg right now over 1570 miles. I drive almost entirely to work and home. The path is mostly downhill one direction, mostly uphill the other. One direction is usually 150-190mpg listed when I turn off. The opposite direction is usually 50-60mpg. (8.7 miles each direction, 17.4 daily)
    Back of the envelope yields: (170 + 55) / 2 = 112.5. That's not even close to 76.0. What's going on?
    49,488
    welcome!
    the average mpg on the dash is 76, and computed at the pump is also 76?
  3. nema32
    nema32 New Member
    Albuquerque NM
    2022 Prius
    yeah, they are in agreement. I'm just trying to figure out how the individual driving sessions can average much higher when that's obviously not the case.
  4. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    Take a few minutes to dive deep into your OM. It actually explains why you are seeing what you’re seeing. Also, get ready for some REALLY IGNORANT responses! ;). I’ve got a’22 also, and see very similar averages. Again, the manual actually addresses it and it actually makes sense.
    Some here believe (and remember, beliefs are seldom based on real world facts anymore) that Toyota has something to gain by convincing you that you are getting better mpg than you are (apparently believing, also that Toyota thinks none of us can do basic math), so get ready for the conspiracy advocates to chime in on this: trust your math and your manual. ;) ;)
    #4 Doug McC, Aug 20, 2022
  5. fuzzy1
    10,169
    You are using the wrong math to compute combined trip average, because the denominators don't match. Try this instead:
    Downhill fuel used: 1 / 170 gallons per mile = 0.005882 gal/mile
    Uphill fuel used: 1 / 55 gallons per mile = 0.018182 gal/mile
    Round trip sum = 0.005882 + 0.018182 = 0.024064 gallons per 2 miles round trip
    Round trip MPG = 2 miles / 0.024064 gallons = 83.1 MPG.
    83 is much closer to your displayed 76, than was the method you used. And considering that you gave round numbers, that is close enough.
    Most countries express fuel economy as liters per 100 kilometers. If we used either that, or an English equivalent such as gallons per 100 miles, then we could do a simple average and get the right answer.
    #5 fuzzy1, Aug 20, 2022
    CR94, bisco and alanclarkeau like this.
  6. nema32
    nema32 New Member
    Albuquerque NM
    2022 Prius
    Ugh. Thanks for taking time to explain that error. I'm glad it was that simple and that it more or less matches using the right method. It's just embarrassing b/c I did actually pass diff-eq a few decades back.
    fuzzy1 likes this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    The other thing I recall from High School mathematics - you can't average averages (unless - as mentioned above, the denominators are identical, or at least similar).
    Doug McC likes this.
  8. Mendel Leisk
    38,726
    Oh geez, I've got to rise to that:
    Doug McC, bisco and fuzzy1 like this.
  9. fuzzy1
    10,169
    My own diff-eq and complex variables and linear algebra are also extremely rusty by now.
    alanclarkeau likes this.
  10. alanclarkeau
    7,044
    7,584
    ditto :oops: . I did schooling BC (before calculators). Even slide-rules were ... I think steam driven.
    But - since school - I haven't knowingly used calculus, differential equations - or most of the trigonometry I learned. BUT - the learned concepts are undoubtedly in use by my brain still, 50 years later.
    Doug McC and fuzzy1 like this.
  11. Doug McC
    1,004
    377
    Midwest
    2022 Prius
    LOL I wondered how long you could let me get by with that! ;)
  12. Mendel Leisk
    38,726
    It's funny, looking back on the stuff we were taught:
    Penmanship
    Arithmetic
    Geography
    History (ancient history)
    Today's grade school curriculum pale. Maybe for the best.
  13. alanclarkeau
    7,044
    7,584
    Sometimes I feel like I came from there - the way things are progressing.
    All my cars in the past - you press the button to open the glovebox.
    A friend was telling me that he had to ask how to on his new car:
    Answer: To open the glove box:
    1) tap the car icon (Controls) at the corner of the screen
    2) tap the Glove box button on the screen
    3) The glove box opens.
    4) you roll your eyes just wondering.
  14. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Soon, you will have to buy a subscription to use your glovebox. Thanks BMW!
    Doug McC and alanclarkeau like this.
  15. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Yeah, lots of people have trouble with basic arithmetic. Gallons per mile would be less confusing than miles per gallon. Average mpg is the inverse of the average of the inverses. Thus
    (1/170+1/55)gal./mile/2 = (1/83.1)gal./mile .
  16. CooCooCaChoo
    901
    504
    Cow-lee-fornia
    2023 Prius
    ^^^ You just made it more confusing!
    Mendel Leisk and fuzzy1 like this.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    963
    631
    Monument, Colorado USA
    While most say their dash MPG is under what they actually get, mine is consistently 2-3 mpg less. (Says 59-60 but when I fill it up it's 57-58) I suspect it due to being at 7,000 feet above sea level and our regular gas is 85 octane.)
    Recently, however, I replaced my engine air filter and inflated the tires to 37 mpg (recent cold caused TPMS light to come on and few were low.) Now, the car is reporting 64 mpg so it'll be interesting to see if I actually get 61-62 now.
  18. Mendel Leisk
    38,726
    At least for me dash-displayed mpg is invariably higher than calculated, by an average ~7.5%. I think that’s the consensus here too?
    ColoradoBoo likes this.
  19. fuzzy1
    10,169
    They do? That is the opposite of what I've been reading. Like yours, my dashboard MPG is a bit higher than reality. The vast majority of reports here, at least on my vehicle generation, are similar.
  20. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    My dash reports better mpg most of the time. Sometimes it is correct.
    10k @ 52.9 mpg
