Avocado Prius - My first Prius
Discussion in 'Newbie Forum' started by Georgios, Feb 6, 2018.
  1. Georgios
    Georgios Member
    126
    85
    Chicago
    Hi all.
    I am the newest owner of 2 gen Prius, Its SIlver Pine color but to me is not silver. I called it Avocado.
    I have always had Audis, older and newer and now I am thrown in a totally different world of Prius.
    I have driven the 2nd gen prius for couple of weeks back in 2014 and I know what to expect as of drivability and dynamics and fuel.
    I bought 148K miles car with some extra options but not fully loaded. has JBL, Xenons, and I dont know if its a Base or Touring
    Its a 3 owner car, owned always locally in Chicago and maintained in the dealer up untill
    2015. Came with plenty of paperwork and carfax and somehow car has little to no rust on the underbody.
    I am a DIY person who never neglect his cars
    Before I even brought the car home I have bought 2 front rotors and pads, rear drums and shoes
    as well as 5w30 oil with genuine toyota oil filter.
    I also will buy 2 gal of coolant and 4 qts transmission oil from the dealer.
    I also bough a Chilton repair manual book, off ebay for $10 in great condition and immediately read most of it
    I can say comapring to the Audi world I come from, this car is totally easy and most importantly pleasant to work on before I even start the work on it.
    For reliability and cost of ownership its not even comparable of any audi
    The car had a big door dent but not an impact (it was pushed by a truck rear bumper) so the door opens and closes without it being deformed.
    The car drove fine but had terrible noise from the front when runnung and driving. Turned out the water pump was to be replaced as the noise was coming from there and the second noise was from the wheel bearing.
    The car dealer replaced them for me but when i saw video and read the repair manual
    of how to replace those I was laughing how easy and cheap is to do that. Try do that to my old A8
    I am concerned for a few things as I have not driven the car yet more than 50 miles but as far as I see it shouldnt be a problem for the car
    I just dont know the condition of the battery and have no time to take it out and measure it untill spring comes. I watched and read plenty of videos how to do the removal of the interior to reach the battery.
    Watched plenty of videos for failed batteries at around my milage, but I assume since I watched battery videos it seemed to me that all prius fail on the battery
    But probaly is because I am searching for battery problems online and cant actually see how many % of all priuses are like that.
    If the battery fails in around a year from now I wouldnt complain as I will cahange it myself.
    I need to put new tires as those are kind of worn, Front ones doesnt even hold air for long. I have an extra set of 15" kumhos that I bough new couple years ago and will install them for now.
    the only thing is my extra set is 195-65-15 and not the 185-65-15. That means I have a little bigger and wider tire.
    Would I do a mistake if I put them? I am thinking a little extra width and stability wouldnt hurt it much?
    Thanks
    DLC82SV, pilotgrrl, RCO and 2 others like this.
  2. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    The 195s would work fine...ive had 2 gen 2 prii...always ran the 195/65r15s...205s will even be fine too, if so desired...now , with the oil changes...the total amount with filter is 3.75quarts...not 4...if you go 4 you will overfill and it will get into the MAF and then youll have to clean/replace it...There are 2 batteries in this car...the HV battery under the back...and a 12v battery ,located in the back passenger side corner...this battery powers up the computers when you start up into the ready mode...there is no starter to crank...i would check your air filters in the engine and in the glove box...the cabin filter can get really dirty fast...you'll have to take the plastic glove box out...but thats easy...The coolant should be the oem toyota pink coolant because the coolant not only cools the ICE(engine) but it circulates in and around the invertor(silver thing under the hood...)so the long life fluid is needed for this...spark plugs are easy enough just watch the tops when taking them out....if your mileage maintains between 40-48 to 50 in the winter the High Voltage battery would probably be just fine...my 2004 has close to 300000miles now(daughter has it )and the HV battery is fine...we have had to replace the 12v battery 3 times over its life ,though...Brakes and rotors should last 150-200000 miles...friction braking is minimal in this car due to regen braking...friction braking is used under 7mph and in panic stops...disks up front and drums in back...i replaced drums at 250,000miles...and we have had one wheel bearing...the bearing is all self contained...straight in straight out...dont know if you have keyless entry or not ,but if you do...make sure the buttons under the steering column are on for this function to work...Now when the time comes you will see a maintenance light show up on the dash from the last reset...it turns on at the 4800-5000 lapsed mile mark from last reset...this is just a reminder of oil changes...etc...to reset it ...hold the odo button down and hold the start button down at the same time and hold for 3-5 seconds(foot on brake) just like starting up ...odometer will have dashes then the miles will show up when complete...btw a good water pump belt would probably in order just for good measure...,as well...
    pilotgrrl, Aaron Vitolins and RCO like this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Welcome to Prius Chat Georgios. You have made a very promising start with your new car. We all hope it will bring you many reliable miles before you need any of that major repair stuff that comes along with age. It sure has with my ancient body. Fortunately, my car's a hell of a lot younger than me!
    pilotgrrl likes this.
  4. Georgios
    Georgios Member
    126
    85
    Chicago
    Thank you!
    Today i replaced the tires and OMG. The car feels and handles a lot better with the new size tires. And you cant really tell the difference on the look. I only need an aligment as the steering wheel is a bit off but will happen tomorrow.
    I put fresh mid grade gas. Replaced the oil and filled up with 3.9 qts of oil (says in the manual when replacing filter too)
    And just like wb9tuj said i reset the service.
    I replaced the air filter and cabin filter with those on the picture. The old ones were actually almost new so i know someone took care of it regularly. I found a sticker for the extended warranty they had so looks like well maintained but i will still perform whats needed.
    In the next few days i will replace rear and front brakes as the front ones look pretty rusty but pads are still thick enought to not be changed. But since i already have discs and pads as well as drums and shoes...why not to refresh them.
    I was thinking to buy the rear wheel brake cylinders as i found Advics is the oem manufactorer and they are available outside toyota for cheaper. But i read in the repair manual that the brake flush will not be easy and dealer has to do it. But my brake fluid in the reservoir looks very bright so i believe its not more than a year or two old. Usually on the 3rd year it darkens a lot so for now i will hold it there.
    And after the weater gets a bit warmer i will flush the 2 coolant systems and the trans fluid and i will not be surprised if they are replaced but still will have to check it off the list.
    I found 1 small problem. My passanger side HID comes on and off from time to time. Read in the owners manual that power to it has to be restored or something. What would you advice me to check?
    #4 Georgios, Feb 7, 2018
    RCO likes this.
  5. Prodigyplace
    12,673
    11,829
    Central Virginia
    Prius brakes tend to get surface rust because they are not used as much as a regular car. When you brake normally regenerative braking handles that, recharging the traction battery.
    @Mendel Leisk has advice on assembly and lubing the pins for the brakes. He should be here in a while.
    pilotgrrl and RCO like this.
  6. wb9tyj
    389
    95
    Indiana and Nevada
    HID bulbs...When they start to go on-off ,the HID bulbs should be replaced...Both of my prii 2004, and 2009 had HID...Do not buy cheap Amazon or ebay bulbs...they wont last long...If your hands are small you can change the bulbs without taking off the front bumper, however, if you have larger hands...taking off the bumper cover to loosen up the headlight casing will make the installation easier...i used 4500-5000Kelvin bulbs ...they seemed to give the right amount of light...any increase in K temperature ,the light becomes blue and light output diminishes...
    Prodigyplace and RCO like this.
  7. Georgios
    Georgios Member
    126
    85
    Chicago
    Thanks for the advice WB9. After i checked what the OEM ones go for i will never buy cheap replacement. Under $30 per bulb is a no btainer. I am amazed by the cheap OEM parts prices of Toyota.
  8. Prodigyplace
    12,673
    11,829
    Central Virginia
    IIRC my son used GE ones when he had his Gen 2. Never needed to replace them again.
    kenoarto and RCO like this.
  9. Georgios
    Georgios Member
    126
    85
    Chicago
    All good so far. Fixed the door and found a complete door for $125
    Now i am about to change the trans fluid and i have option of using the Castrol CVT. Would that work on the Prius and what manifacturer standarts need to cover?
    TC and FE?
  10. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    OEM Toyota WS (World Standard) is the stuff you want. People think "ooo, dealer stuff is expensive!" but most dealers sell it under $10/quart, or you can get it on Amazon for a few dollars less. I'm sure that Castrol stuff is around $10/quart anyhow, so why not just buy the stuff Toyota specifies if it's around the same price?
  11. Georgios
    Georgios Member
    126
    85
    Chicago
    Yes. Actually i do not try to save money as the local dealer sells is for $9 plus tax which is incredibly cheap for oem part but i feel like its made by mobil super whoch is lower brand of Mobil 1 and WS isnt really a synthetic oil.
  12. egg_salad
    545
    426
    Las Vegas, NV
    Hundreds of millions of miles have been put on Prius transmissions using WS transmission fluid and CVT failure is rare. Use whatever you want.
    #12 egg_salad, Feb 17, 2018
    DLC82SV and RCO like this.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Keep in mind the "transmission fluid" has a hard life in the Prius not because of heat or anything like that but because it has a few hundred volts running around it. It has been found that some of the so-called comparable fluids are actually slightly conductive. That's a great way to destroy the entire HSD. Just buy the stuff Toyota put in there from the factory. It is super cheap and it is made to withstand high voltage systems of the hybrid.
  14. Georgios
    Georgios Member
    126
    85
    Chicago
    First problem i am facing:
    I replaced the transmission fluid and drove the car around 50 miles. Car drove beautiful.
    On the highway the red triangle and check engine came as well as VCS(but went away) i thought maybe the new oil leaked out. But its all as i left it. No leaks
    I went home ..like 10 miles away. It is soaked up for the last 2 days here
    Now i checked the code in autozone and it shows P0A93 - Which in the Chilton manual says it is Hybrid powertrain control module. And in the scan tool says coolant performance or water pump.
    Help
  15. bisco
    52,380
    maybe inverter pump? you might need torque or tech stream for sub codes.
    RCO likes this.
  16. Prodigyplace
    12,673
    11,829
    Central Virginia
    Did you decide to use Toyota WS fluid?
  17. Georgios
    Georgios Member
    126
    85
    Chicago
    Yes the dealer fluid. Old one was dark but Not really bad and had some sludge on the drain plug which is magnetic.
    Now i drove the car....drives just like normal but when i shut it of then I usually hear Drrrrrzzzzzzzz... Now this sound more tiny sound like its a cartoo ln caracter ...more high pitch than before
    Checked the 12v battery...remains steady 12.3V
    So if that noise is different then thats what i should look at? And where that noise come from by the way? The pump we talking?
  18. Prodigyplace
    12,673
    11,829
    Central Virginia
    Some noises for the Prius are normal. It uses an electric brake accumulator pump, for instance. Do you have another Prius driver who could listen for you to see if it is abnormal?
    kenoarto likes this.
  19. Georgios
    Georgios Member
    126
    85
    Chicago
    I know how it sounds from a while ago and my sounds normal.. ...
    Will start by replacing that coolant with pump. Really wasnt expecting reliability issues .kinda dissapointed
  20. Prodigyplace
    12,673
    11,829
    Central Virginia
    It would be wise to check the trouble code freeze frame data (snowflake icon) to direct troubleshooting. Just replacing parts can get expensive fast.
