Avoided warm-up cycle after overnight park
Discussion in 'Gen 4 Prius Technical Discussion' started by GreenJuice, May 19, 2017.
  1. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    Had my first experience yesterday of my Gen 4 not triggering the warm-up cycle on starting in the morning after parking overnight. This has never happened to me before on the Gen 3 or Gen 2. It's good because I have a 200 yard run before a long downhill commute to work in the morning; which means if I can time the traffic light approaches well I could potentially make my entire commute on electric only.
    I monitor using ScanGauge II and had always assumed the warm-up cycle trigger was based on engine temperature on starting (at least it seemed to be so on the Gen 3 and Gen 2). I wonder if on the Gen 4 there is another trigger related to the time passed after stopping.
    I was home late the night before and it was about 8 hours since I parked up. Coolant water temperature (cWT) on ScanGauge showed 23C (73F). Same values for the inverter coolant water temperature (ICT) and Boosting Converter temperature - upper (BUT) on starting. Battery State of Charge (SOC) was 48% (3 bars on display). I made it about 2 miles before getting caught at some traffic lights and had to accelerate away, triggering the ICE and the warm-up cycle.
    Another interesting comparison I have observed is that the first ICE shutdown after warm-up cycle takes place as low as 36C (97F) with some variability, which is noticeably less than on the Gen 3 and Gen 2 (which were both fixed and reliably happened at 40C / 104F). If you manage to keep avoiding ICE-on with slow accelerations the car seems to allow temperatures to fall away almost to external temperatures, which was not possible on the Gen 3 or 2. If you trigger ICE-on again, the shutdowns take place at successively higher temperatures.
    All my driving is in Eco Mode and with eco settings on all choices.
    I'd be interested to hear if anyone knows about the Gen 4 warm up cycles and how it is programmed differently from the Gen 3 and Gen 2.
    RCO likes this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Ambient air temperature is the trigger. I haven't worked out the exact figure but it's somewhere around mid teens deg C where above that the warm up cycle doesn't trigger until the HV battery level falls below 2 bars or you push the accelerator pedal too hard.
    RCO and Trollbait like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've a similar "first thing in the morning" start. IF I've got at least ½ battery charge, when I park the night before, I ensure the Climate Control is OFF. And, first thing when I POWER up, I press her EV Button.
    No, not every time - probably 95%. But, she has a mind of her own, and 5% of the time, she'll start the ICE straight off, or give "EV UNAVAILABLE". She reckons she doesn't need to give a reason.
    goinskiing and RCO like this.
  4. Mendel Leisk
    41,861
    This seems to me to be the number one reason the fourth gen's are yielding such high mpg numbers. Hopefully not overtaxing the battery.
  5. Trollbait
    12,665
    Calling for EV mode on first start up in previous generations would delay the ICE turning on also. If there was enough charge, the battery wasn't too cold or hot, etc.
  6. Mendel Leisk
    41,861
    With the 4th gen I believe the car will sometime start and can be driven without the engine starting up, without the EV button being pushed.
    Ramo_958 and kithmo like this.
  7. bisco
    52,351
    i never got more than 15 or 20 seconds on a warm day with full battery before the ice fired in my gen 2's.
  8. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I have that in the mornings, as long as climate is off I can get out of the garage, drive up the close, and about 300 yards down the road before the ICE cuts in. I usually have about 50% charge in the morning and this is driving in normal mode.
    Ramo_958, RCO and Mendel Leisk like this.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes it does, I assumed that's what the OP was referring to.
  10. Tideland Prius
    16,610
    Yeah. For those who are unfamiliar, here are the stages of warm-up operation for the Gen 2 and Gen 3
    Gen 2
    The Five Stages of Prius Hybrid Operation | PriusChat
    Gen 3
    Gen3 warming up stages | PriusChat
    I believe the stronger electric motors in the Gen 4 allow the engine to remain in S0 for longer because the motor is powerful enough to power the car at low speed and doesn't require the engine to assist like it does in the Gen 2 and Gen 3.
  11. alanclarkeau
    7,045
    7,593
    Thanks - that explains a lot - and I suspect Gen 4 is based on it.
    Mine will go to 37km/hr cold in EV mode (about 50 when hot), and one time I tried it out on a mix of level/slight-downhill (no traffic either), went for about 2½km then when the battery hit 3 bars engaged the ICE.
    RCO, kithmo and Tideland Prius like this.
  12. dstahre
    dstahre Member
    74
    35
    Cahokia
    Four Touring
    My understanding is that the consideration is catalytic converter temperature. Don't know why you didn't get into the warmup though
  13. soldierguy
    soldierguy Active Member
    108
    245
    Maryland
    I thought it was a combination of vehicle speed and engine temp (coolant and/or oil temperature, or maybe catalytic converter temp) that triggered the warmup cycle.
    Very consistently, if I have not driven the car in quite a while (all day or overnight), the engine comes on like clockwork the first time I pass 20 mph. At work in the summertime, outside temps often hit over 100 degrees Fahrenheit, yet if the car has been parked all day, engine warmup starts like clockwork as I pass 20 mph. It does this even though when leaving work at the end of the day, the first mile is downhill.
  14. alanclarkeau
    7,045
    7,593
    Yes, that's about right - 38km/hr on a cold engine will kick it to life. But if the heater (Climate Control when the requested temp is MORE than the ambient) is on, it'll come on immediately, as the heater needs the ICE to be running to warm you up.
    Ramo_958 likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think the engine comes on at high temp low speed simply to bring the cat. up to its optimum working temperature.
    alanclarkeau likes this.
  16. Rgtanna
    Rgtanna New Member
    Australia
    I'm currently driving a Toyota CH-R Hybrid in Japan. Back home in Australia I drive a Lexus CT200h so I am familiar with the warm up cycle.
    I was surprised when driving the CH-R, the warm up cycle did not run after parking overnight. There must therefore be more similarity between the Gen 4 Prius and CH-R than the Gen 3.
    On a side note, the transition between engine and battery is significantly smoother than the CT200h.
  17. alanclarkeau
    7,045
    7,593
    Gen 4's transition is like that - unless you realllllly try, you won't notice it at all, and even then, only rarely.
  18. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Can't say I've ever noticed any transition between ICE and EV on any Prius. I've had the Gen 3, the Prius+ (or v wagon in US) and now have the Gen 4, all ran on Shell fuel. Maybe I'm too thick skinned to notice :rolleyes:
  19. qettyz
    qettyz Active Member
    181
    206
    Finland
    Interesting as my 2014 Auris/Corolla should be totally like GEN3 hybrid system on Gen3 prius.
    But i have had two successfully EV only getaways after work when car has been on hot parking lot(well not so hot, but something like 30C).
    Car has been sitting about 8 hours.
    Havent monitored it via Hybrid Assistant but i try do that next time when i keep car in sunshine and think that maybe it does not fire ICE and check temps from OBD2.
  20. alanclarkeau
    7,045
    7,593
    If it's a cooler day - and Samantha thinks I want the heater on, she'll kick the ICE on almost immediately I press start. I've got about 1-2 seconds to turn Climate Control OFF and hit the EV button after startup - or her ICE will be on.
    In reality - if I have Climate Control off after the ICE starts (i.e. - the heater OFF as I don't really like heaters unless it's actually cold) - I don't think it makes an appreciable difference to l/100km whether her ICE starts when I first hit START, or whether I run her in EV mode till the battery is low before her ICE starts.
    The ICE WILL start at some time - and if the battery is low, there are no opportunities to play games like Pulse-n-glide etc.
    kithmo and RCO like this.
