AWD owners: does the smaller tank bother you?
Discussion in 'Gen 5 Prius Main Forum' started by priusmouse, Aug 27, 2023.
  1. priusmouse
    priusmouse Member
    253
    85
    Long Island, NY
    2023 Prius
    Looks like the gas tank in the AWD version is .8 gallons smaller than the FWD/regular versions.
    Is this noticeable to anyone?
    I’m coming from the 2017 L eco, which got less milage, so maybe for me it will work out to about the same milage per tank anyway
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Going from Gen-3 Prius to Prius PHV meant loss of roughly 2 gallons for me. It was a non-issue. No big deal.
  3. PhoS
    PhoS Active Member
    234
    194
    Nowhere
    2023 Prius
    Limited AWD-e
  4. David Mk.2
    David Mk.2 Member
    61
    60
    Connecticut
    2023 Prius
    I have the AWD and didn't even know this. Not a concern, it's already plenty long enough between fill-ups
  5. Hammersmith
    Hammersmith Senior Member
    2,010
    2,002
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Roughly 450 miles between fill-ups for my Limited(+/- 50 miles depending on driving habits and conditions). About the same as my 2010 Prius II, so it works fine for me.
  6. Chichiwood
    Chichiwood Junior Member
    Usa
    Not a big deal for me!
  7. flarecde
    flarecde Member
    NY
    2023 Prius
    Limited AWD-e
    I came from a Prius C with an even tinier tank. I think I get like 150 more miles to the tank.
    Besides, who fills their tank? For optimal weight efficacy, you should only put in enough gas to make it to the next gas station, right? Right!?
  8. leftbrarian
    leftbrarian New Member
    Corner Brook, NL, Canada
    2023 Prius Prime
    SE
    By the fuel economy ratings, you definitely shouldn't get 150 miles more to the tank than the 2023 AWD. hah
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,143
    749
    Monument, Colorado USA
    No, my 2021 LE AWD has the lithium batteries so get's better mpg than my wife 2017 LE with nickel-metal batteries.
    Since my old Chevy had a gas-line freeze in the winter here, because it was low on gas, I've always refilled our tanks before they get to 1/4 full (in the winter) but wonder if this is even a problem with Toyota's? Anybody who lives in cold weather ever had a Toyota fuel line freeze up?
  10. john1701a
    12,797
    5,280
    57
    24 winters of Prius ownership in Minnesota. I have never even heard of such a concern. How would that happen, a vehicle with an unsealed tank absorbing water?
  11. Trollbait
    12,351
    No longer a problem with E10. Before that, if some water was picked up from a gas station, the fact it was heavier and didn't mix with the gas mean a slug of it could end up in a line and freeze when parked. Probably not a big concern back then, but I think if you are unlucky enough to have had it happen, it wouldn't matter which brand or model.
    fuzzy1 likes this.
