AWD vs FWD
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 14, 2025 at 8:07 AM.
  1. HamiltonPrius
    HamiltonPrius Member
    119
    65
    Parts unknown (in the USA)
    Which trim level on a Prius has a higher trade in / resale value…a AWD or FWD model? I would think it’s the AWD model for the simple fact it’s a more expensive car by $1,400 to begin with. Is the answer as simple as that or when it’s time to sell the car depreciation sets in and the difference in the original selling price equals out?
    #1 HamiltonPrius, Oct 14, 2025 at 8:07 AM
  2. Moving Right Along
    Moving Right Along Senior Member
    709
    555
    In general, anything that makes a car more expensive is going to add something to its resale value. The amount any individual option adds will shrink over time with depreciation, but there should still be some kind of premium on an all wheel drive Prius as opposed to a front wheel drive, even after a decade or more.
    But if you don’t actually need all wheel drive and you’re considering whether or not to buy a car with it, the option is never going to be worth as much as you paid for it. That’s the nature of car prices, with very few exceptions.
  3. HamiltonPrius
    119
    65
    Actually I’m torn between 2 cars. The one XLE doesn’t have AWD the other does. But the car with the AWD is a much better deal, it’s actually a fantastic deal!
    I don’t want the AWD, I would rather get the better gas mileage from the FWD car but the overall deal for the AWD car might be too good to pass up.
    #3 HamiltonPrius, Oct 14, 2025 at 8:52 AM
  4. Winston Smith
    Winston Smith Active Member
    309
    219
    OH
    2024 Prius
    LE AWD-e
    The Prius is a ton and a half car on weirdly skinny tires. Put all of a couple hundred hp through only two of those in slippery conditions and you will get outrageous understeer. I've found AWD occasionally helpful, though it does not eliminate understeer.
    The AWD weighs something like 140 pounds more than the 2wd, so I'm sure there is some penalty, but it isn't the penalty associated with mechanical AWD systems that may induce huge inefficiencies when not in use. If the EPA formula yields a 2% drop in efficiency, I wouldn't dispute that, but I would dispute your ability to notice the difference outside of very controlled conditions. I see greater differences in efficiency if I turn on the climate control. The difference between routes and driving styles will dwarf the 140 pound weight penalty.
    The car below is AWD.
  5. BiomedO1
    BiomedO1 Senior Member
    3,225
    1,706
    SacTown, Ca
    If your talking about resale; It's whatever the local market will bear. AWD doesn't command a much higher price than a FWD in the southern states. High trim cars will be priced similarly to those of low trim cars; again whatever the local market will bear. You may get a few hundred extra for that few thousands in extra options - but nobody really cares on a depreciated car. Take whatever offered or leave.........
    Just my two cents......
  6. Mendel Leisk
    41,050
    The AWD imposes additional maintenance if I’m not mistaken. A periodic fluid change?
    BiomedO1 likes this.
  7. BiomedO1
    3,225
    1,706
    SacTown, Ca
    Yep, slightly heavier and a mpg penalty. That couple of mpg starts adding up as you rack up the miles.
  8. reservoirblue
    reservoirblue Member
    Woodacre, CA
    2024 Prius Prime
    SE
    No reason to leave it on "weirdly skinny tires". I switched to a wider option early in the game.
  9. Mendel Leisk
    41,050
    Not everyone has deep pockets, and it does grate, buying a brand-new car, and near-immediately starting to replace stuff.
    #9 Mendel Leisk, Oct 14, 2025 at 1:29 PM
  10. VelvetFoot
    VelvetFoot Member
    251
    63
    New York State
    2026 Prius
    195's are skinny?
    edit: Although I will say that 195 55 16 's were harder to find/more expensive to find for my MINI.
