AWD XLE or Prime XSE?
Discussion in 'Gen 5 Prius Main Forum' started by Teleplayer, Sep 25, 2023.
  1. Teleplayer
    Teleplayer New Member
    26
    17
    Northeast US
    2023 Prius
    I'm in shopping mode, planning to get a Prius in the next couple of months (let's assume for purposes of this conversation that availability/markup won't be an issue ;)).
    I live in upstate NY where it snows. I've owned AWD vehicles for the past 20 years, and I guess I'm conditioned to think that way. However, I don't do a daily commute (semi-retired, work from home). Wife has an AWD Mazda CX-5. That said, there may be times when she's at work and I will need to drive on snowy roads. It's rare that either of us would be venturing out regularly in the midst of a big storm or in the aftermath of one unless there's some emergency (unlikely but you never know).
    I'm having troubled deciding between the AWD XLE vs FWD Prime XSE. Either vehicle would get winter tires/wheels, with the AWD probably being slightly superior to the FWD. But maybe not by a lot, because I've done some research and have talked to a few friends. It's pretty well known that a FWD car with good winter tires will do just fine in all but the most extreme conditions.
    The Prime will cost more than the XLE. As appealing as it is to go to the gas station maybe once a month with the Prime, I'm weighing that against the still excellent MPG I'd get with the XLE and the slightly better winter performance of the AWD (i.e., peace of mind). Furthermore, given my budget I'd probably get a couple options on the XLE that I wouldn't spring for on the Prime. So there's that too.
    And how about the decreased performance of a Prime in colder weather? Combined with the decreased efficiency of winter tires I'm wondering how much these factors would diminish any advantage or the Prime.
    If anyone here has gone through a similar decision process I'd be interested to know your thoughts and conclusions. Thanks!
  2. Trollbait
    12,346
    How far are the trips you do take? If short enough that nearly all your miles are on electric, maintenance of the engine side is something to consider. Maybe even consider a BEV. Range loss is a thing for winter, but most available have well over 100 or 200 miles of range.
    As for the AWD vs FWD Prius, I'd think you would be fine with just FWD between the winter tires, low need to be out in the snow, and second car with AWD.
    Louis19 likes this.
  3. Mendel Leisk
    40,574
    I find it’s neck-and-neck, going from 17” Michelin Primacy MXM4 in spring/summer/fall, to 15” Michelin X-Ice through winter.
    51,140
    what are you driving now?
    samsprius1 and Mendel Leisk like this.
  5. Louis19
    Louis19 Active Member
    396
    368
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Here , 4 winter tires are mandatory , does not care if its AWD,FWD or propulsion. Major EV range hit is more important with outside temperature ..could be a 20 to 25% range reduction. (Heatpump working harder)
    My 4 winter tires are mounted on steel wheels , being heavier than the original wheels and tire , I suffer an additionnal 8 to 10% range reduction.I live in a suburb and FWD is ok even in very dense snowfall .If you don't climb a mountain every day , you should be Ok with a FWD.
    So january and feburary is tough for the Prime range but very good in spring, summer and autumn. For my needs , on a yearly base I drive 75% of the time on EV .ON very cold spells the ICE kicks in to keep me cosy , and keeping the windshield defrosted as the heatpump cannot deliever enough heat.
    #5 Louis19, Sep 25, 2023
  6. AndersOne
    AndersOne Active Member
    334
    193
    Europe
    2023 Prius Prime
    On another note, the Prime has significantly more horsepower, especially for the emoter. Is that something you can actually really feel in many situations?
  7. Hammersmith
    Hammersmith Senior Member
    2,004
    2,000
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I faced the same choice and went AWD HEV. For me it was the temps that made tipped the balance.
    I live in ND and the average daily high temps are below 40 five months out of the year, and the daily low temps are below 40 seven months of the year. I know there's some set temp where the Prime will automatically run its ICE on startup no matter if the batt is full or not. That meant there was a good chance I would lose the benefits of the PHEV for a third of the year or more.
    Plus, 80-90% of my usual trips are less than two miles(the remainder are 50+ miles). Normally that would be a positive for the Prime, but not if it's so cold the ICE ends up running for the majority of the trip anyway.
    I will also likely do more winter highway driving than the OP, so the AWD is worth a little more to me.
    Finally, I was able to find an HEV with the exact option/color combination I was looking for back in April. I knew it was going to be six months or more before I was going to have any real chance at finding a Prime fitted out just as well.
    If I lived in a milder climate where I could have taken better advantage of the PHEV, I probably would have gone the other way and gotten a Prime. I lived over 10 years up here with a FWD gen3 and got around just fine with all-weather tires(Nokian WRG3 & WRG4), so the AWD is a nice bonus, but it's not something critical.
    otatrant likes this.
  8. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Neither! For a few bucks get the limited AWD! 2500 miles under my belt this is my third Prius by far the nicest quietest, comfortable, best looking and fastest I’ve had still getting in the upper 40s MPG and I like sport mode !The limited has features you can’t get on any others, only a suggestion do your research and get what you like! I’m in the same boat if the weather gets bad I don’t have to go anywhere and if I do, I’ll take my wife’s RAV4 hybrid! Hope you can find one. What are the dealers telling you about wait time or availability? I also thought about an EV, but with the weather here, just not worth it! I am in the upper Midwest temperature sometimes below freezing!
  9. otatrant
    otatrant Active Member
    195
    130
    San Francisco
    2023 Prius Prime
    XSE Premium
    Traffic Jam Assist on the prime is a nice feature I don't think is available on the non prime. I have never really enjoyed sitting in traffic but the couple times I have used it really took the stress out of it. Something to consider.
  10. Hammersmith
    2,004
    2,000
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Good point. Living in ND, it obviously wasn't a big selling point for me. lol. But for someone living in a more dense area, I could see the appeal.
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,139
    747
    Monument, Colorado USA
    We have two Prius' ('Prii?") and the 2017 is front-wheel drive and my 2021 is AWD. AWD is better, by a bit, on snowy roads but it really makes a difference on icy roads....huge improvement.
    So if your area can get icy, I'd go with the AWD....and, no, I don't put winter tires on her, just all-season tires.
  12. Curtis86
    Curtis86 New Member
    Kentucky
    2023 Prius
    XLE AWD-e
    Picking up a loaded XLE AWD Wind Chill Pearl tomorrow morning! I’m getting out of a ‘23 F-150. Got the Prius for $36,239 + ttl. Found one dealer within 300 miles with no add ons or mark up aside from their doc fee with one in stock. Pretty excited to get into an economical vehicle.
    ColoradoBoo likes this.
  13. Teleplayer
    26
    17
    Northeast US
    2023 Prius
    Lots of good food for thought, thanks to everyone who replied. I'm currently driving a four door Jeep Wrangler - a vehicle that shares many attributes with the Prius (....I'm kidding of course :D).
    I don't take regular trips, and I probably drive slightly fewer miles in winter.
    The comment about taking a look at the AWD Limited isn't a bad suggestion either. For the price of the Prime I could have a few more gizmos and doodads to mess with, which is always fun.
    I think the FWD vs AWD is probably a wash for my use case. If I had a daily commute and a requirement to be in an office, that might sway me to the AWD.
    Essentially the Prius will take the role of a second vehicle for us. The wife does have a daily commute in her CX-5. The Prius will be more "mine" for errands and maybe for our longer road trips and vacations because it will be so much more efficient.
    I've got some more thinking to do. I know AWD XLEs and Premiums can be found in my region for MSRP. I'm not sure that's the case with the Prime, and that may be the deciding factor. I'll never pay for a dealer markup, no way no how.
    Louis19 and bisco like this.
  14. Nntw
    Nntw Active Member
    398
    246
    Toronto
    2023 Prius Prime
    My purchase of a Prius Prime was based on being to use it as an EV for commuting, and a hybrid for longer trips.
    That's what we've been doing for the last 2 years with my rav4prime, and what we will also be doing with the Prius.
    I can't speak to your utility rates, but running the rav4prime has been really inexpensive. I charge at off peak hours on a level 2 home changer. Pretty well the only time we burn gas is when we are more than a 40km radius from home, like when we venture out of town.
    I honestly don't see the point of a Prius if you don't buy the plug in.... unless the utility rates are a big factor. In which case, maybe you shouldn't be looking at the Prius at all. The Corolla variants have essentially the same powerplant, are cheaper, and in the case of the Corolla Cross, have more cargo room.
    So Prius prime or Prius awd? Prime, or get something else.
    #14 Nntw, Sep 26, 2023
    Louis19 likes this.
  15. Louis19
    396
    368
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I totally agree and my Prius Prime purchase was based on the same reason as yours . But in my province choosing a Prime versus the hybrid version is kind of a no brainer because of goverment incentives makes the Prime cheaper the the regular hybrid...don't think that the OP has access to incentives , he lives in the USA
    as for corolla variants ,utility rates I agree with you.OP is facing also above MSRP price scam in some USmarkets.
    #15 Louis19, Sep 26, 2023
  16. Mendel Leisk
    40,574
    What year, condition, and is it paid off?
