Awesome deal on a 12/3 extension cord
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, Feb 13, 2013.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Unless I am missing something obvious, this is a really good deal on a 12/3 extension cord.
    Home Depot is selling 75ft 12/3 extension cord + 2' tri-tap 12/2 for $19. I paid $22 for my 50' 12/3 on Amazon just 2 months ago (which was a really good deal as well).
    Can anyone find anything wrong with this product? I'm ready to go buy a few.
    51,155
    i'm not sure if there is any way to tell the true quality of an extension cord from outward appearance. it usually becomes known after many seasons of hard use.
    Andyprius1 likes this.
  3. mrbigh
    3,686
    699
    Long Island, NY
    depending on the load you will use on that 75' 12/3, 12/3 may not be enough to transfer the 16 Amp required on a 20Amp. electrical circuit for the PiP EVSE.
    Reading over the shortcut you included, it's stated " Light duty" merchandise. For a temporary use of a hedge trimmer or electric leaf blower may be sufficient enough.
    fotomoto likes this.
  4. Electric Charge
    545
    133
    Syracuse, NY
    I didn't think the charger did more than 13-15A @ Level 1?
  5. Electric Charge
    545
    133
    Syracuse, NY
    Forgot to include the link, sorry. Fixed the post.
  6. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Agreed. I'd suspect folks needing an extension cord will be using it outside, in the sun, and in the summer.
  7. Electric Charge
    545
    133
    Syracuse, NY
    The light duty refers to the jacket, not the copper. Most people use the Level 1 charger on a 15A circuit. I am thinking of this for charging @ work once I get access to an outlet, which I am sure will be 15A, but if this is not a good idea with this cord, then I'll get a better one.
  8. mrbigh
    3,686
    699
    Long Island, NY
    The story is, if you will be connected to a 15Amps wall outlet, after a 75' extension cord you will NOT have access to 120V-15Amps at the other end.
  9. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    Just look for a UL label. If it has this label its ok.
  10. Electric Charge
    545
    133
    Syracuse, NY
    According to HD's website, it is UL listed:
    UL Listed 1-UL Listed
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    110 outlet, I do believe the car draws 12 amps . you should be fine. :)
  12. bisco
    51,155
    12-3 is fine, but 75' might be a bit iffy. do you need that much?
    lensovet likes this.
  13. retired4999
    2,652
    625
    Eau Claire, Wi.
    That could be, I use a 12-3 but I'm only going 25 feet. You do lose a lot with the extra 50 feet.
  14. Electric Charge
    545
    133
    Syracuse, NY
    I just picked 2 of them up, looks like this was a price mistake, as most of the online orders have been cancelled. I plan on putting one in the car, in case I can get access to an outlet @ work once the snow disappears, the other one I will use for my electric snow blower (using a 50' 14/3 now) and my garden tiller.
  15. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    You will still get 15 amps at the end of the cord, but not 110volts. Most ratings are based on a 3% drop. Also, if the system runs for more than two hours, most codes de-rate all of the components by 20%.
  16. lensovet
    2,615
    496
    Burlington, NJ
    i also suspect the only thing "wrong" with this cord is that very few people need such a huge length
