Axial damper
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebeldoc, Jan 10, 2021.
  1. Rebeldoc
    Rebeldoc Junior Member
    Toronto
    2010 with 230k. Started loud rattling/vibrating noise at low speed and when turning.
    Told it is problem with axial damper and it's a costly repair - around $4k. But it won't cause any driving problems - just noise.
    Anyone have any experience with this?
    49,449
    never heard of it, did they give you any description? is it the pulley on the end of the crankshaft?
  3. mjoo
    mjoo Senior Member
    1,119
    1,314
    Michigan
    Do you mean transaxle damper where they have to remove the engine?
    moto g power ?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    I would wonder if you have a bit of engine misfire that is causing the dampener to rattle. Misfire problems are fairly common, dampener problems are not.
  5. Elektroingenieur
    2,515
    3,259
    Three Touring
    I wonder if this was actually axle damper, or what Toyota calls the front drive shaft damper, shown in catalog Figure 43-02, Front Drive Shaft, with part name codes 43474D (right) and 43474E (left).
    I’d suggest asking for a written, itemized estimate, with the information required by provincial law, including the name and price of each part to be replaced. You could post it here or take it to another repair shop for a second opinion.
  6. bisco
    49,449
    4k for that? :eek:
  7. Rebeldoc
    Toronto
    Yes it might actually be the transaxle damper. They told me they had to take apart the engine.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    It’s the spring loaded plate between the trans and engine that’s smooths out the connection between the 2.
    Requires engine removal at the dealer that’s at $150 an hour Ch Ching.
    I wouldn’t put that kind of money in that car with such high mileage.
    But the fact it’s making noise means it’s probably coming apart.
