B- Mode 2001 Prius
Discussion in 'Generation 1 Prius Discussion' started by Joekingiam, May 17, 2011.
  1. Joekingiam
    Joekingiam Junior Member
    59
    Akron, Ohio
    Hey all,
    My question is when I start my Prius, set my emergency brake, shift into B-mode, is then the HV battery charging continuously with the computer regulating it of course?
    Just wondering what the Prius techies can tell me?
    Joe
  2. justkyle
    justkyle New Member
    66
    Plainfield, IN
    2002 Prius
    B mode isn't for Battery, it's for engine Braking.
    Don't think this would do what you would expect it to do.
    I would expect it to wear out your brakes quicker.
    Kyle
    02 Prius
  3. critterz
    critterz New Member
    2001 Prius
    I'm new to the Prius, but from reading up, and my car, B is for engine/regenerative braking mostly for downhill, or slowing down without the use (or less use) of brakes. It does not wear out, or apply your brakes. It uses the traction motor to slow down and that energy is used to charge the traction battery.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    It should have been called J mode, i.e. jake brake.
  6. tochatihu
    tochatihu Senior Member
    9,058
    3,529
    Kunming Yunnan China
    2001 Prius
    If for any reason you want the traction battery to charge up, step on both pedals and shift into "D". It will charge, and it may heat the battery to a degree that some would consider unwise.
