B Mode - ICE never shuts down when car is not moving
Discussion in 'Gen 3 Prius Main Forum' started by co_prius_3, May 9, 2014.
  1. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I've been experimenting with 'B' mode while commuting. While stopped at a light, the ICE never shuts down. Is that normal? It seems like it should, regardless of the drive mode. The ICE was fully warmed up (190 F). I believe the battery was fully charged, as well. It tends to stay charged while in B mode.
    If I switch from Drive to B while stopped at a light, the ICE stays off until the car starts moving. But if it was in B mode already, it never shuts down when the car is stopped.
  2. peterjmc
    917
    188
    Clarksburg, MD
    The ICE will stay on with B mode on during a stop. B mode uses engine braking to slow the car down.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    B mode, which is required by Federal law, is only useful when descending large mountain passes.
    http://www.gpo.gov/fdsys/pkg/CFR-2011-title49-vol6/pdf/CFR-2011-title49-vol6-sec571-102.pdf
    (As implemented by Toyota, there is no maximum speed for B, it just gets lower MPG than D)
    49,455
    b mode is a bad job.
