B1443 Air Conditioner Problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by worrachai, Oct 8, 2018.
  1. worrachai
    worrachai Junior Member
    48
    thailand
    Hi friend
    Do you have any idea for B1443 in Prius3? I checked with Techstream and do Active test. The FACE can open only 36 from the target of 47 and I cannot do the dis-assemble for "Air Outlet Damper Control Servo Motor" by meself because no service area to do that. Do you have any dis-assemble manual for "Air Outlet Damper Control Servo Motor"? I need more advice.
    52,396
    can you access toyota tech info service manual website?
  3. worrachai
    48
    thailand
    I could not found that. Do you have any link or pdf?
  4. worrachai
    48
    thailand
    Now, I recheck by today. Code was dis-appear. After I play the wind control and air from outside switch. Do you have any comment?
  5. worrachai
    48
    thailand
    actually, B1443 was back and air condition was not cool same as last time. Do you have any service manual for B1443, please?
