Back from our SoCal - Denver trip.
Discussion in 'Gen 2 Prius Main Forum' started by srellim234, Jun 26, 2016.
  1. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Well, we're back after a week away. We're very happy with the way the Prius performed. The car was loaded with four adult sized people, four suitcases, ice chest and other things probably totaling around 725 pounds. Started crunching numbers and it looks like just a hair under 44 mpg for the entire trip.
    Leaving southern California using I-40 to Albuquerque then I-25 to visit family in Colorado Springs the car performed like a champ even though the temperature was well over 100* almost all the way. We did discover that the gas mileage drops off quite a bit in the 70-75 mph range. Climbs were no problem.
    After moving on to Denver the week went without issue, including a trip from Arvada (5,400 feet) to Estes Park (7,500 feet). We were able to maintain the speed limits without any strain on that day trip.
    Coming back yesterday was interesting. We left Denver about 6 a.m. so we would have very little traffic and could enjoy the scenery most of the way. The car actually had more difficulty with some of the summits in Utah than it did climbing to the Eisenhower Tunnel and tackling Vail Pass. Even on those, however, the car maintained 55 mph on a depleted battery without excessive working of the ICE.
    Maintaining the 80 mph speed limit in Utah was not a problem on downhills, flats and smaller uphills. The car handled very smoothly and actually appeared to get better mileage at 80 than 70-75 mph.
    The only problem appeared last night about 40 miles before we got back. The "Maintenance Required" light came on. We had it serviced right before we left and there were no other negative indications so we drove it on home and I'll pop over to the dealer tomorrow to have them check the code. I may just have them change the belt early as a precautionary move, too. It has some tiny cracks in it.
    Coast Cruiser likes this.
  2. JC91006
    16,489
    8,402
    The maintenance light was probably not reset after your last oil change. Just reset it now and you're good.
    To reset. Just have your car show the odometer reading, then turn off the car. Find the mph/km button (under your mfd screen), have the button press down while you restart the car. You'll see on the dash, resetting after a few seconds
  3. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Very nice report on your trip. In an 8 yr old Prius? I enjoy reading those kind of comments from the Prius veterans, and it gives me confidence that I bought a reliable car. Thanks!
    (jc, that's a great looking dog!)
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    +1 Maintenance required light is nothing more than an LED on an internal trip counter. If starts blinking longer on startup when you approach an oil change interval and after you've reached that interval it turns on. It doesn't know you've changed the oil unless you actually reset it. And most mechanics have no idea.
  5. srellim234
    1,198
    1,687
    Laughlin, Nevada
    Thanks, JC. I'll send Jorge (Crown's assistant service manager) an email in the morning to let him know about it. Their customer service is excellent and it may just save a future Prius customer some anxiety and aggravation.
  6. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    @srellim234
    You might want to try this method on your Gen II Prius.
    1) Confirm that your Odometer is set to "odometer" (ie. NOT to Trip A or Trip B)
    2) Start with the car off.
    3) Press and hold the ODO button...don't release it until the process is complete
    4) put the car in either Ignition On (2 presses of power button without pressing the brake) or Ready (one push with foot on brake).
    5) Watch the area where the odometer reading shows up...it will show zeros that become dashes, then flashes to the regular odometer reading. Once you see that you can release the odo button and turn off the car.
    This will reset the maint req. light which will flash on briefly in 4500 miles and come on and stay on in 5000 miles.
    Sounds like you had a great road trip. While you were in Utah, did you by chance visit Moab? If not, you should next time you are in the area.
    srellim234 likes this.
  7. srellim234
    1,198
    1,687
    Laughlin, Nevada
    Only passed through Utah. We left Denver about 6 yesterday morning and were home here in SoCal at 11 last night.My wife has to be back at work tomorrow so we only had time to snap a few photos from scenic turnouts on I-70.
    My wife retires next spring so we'll have more time for sightseeing when we visit other family in the Salt Lake City area next June. We also have family with a "vacation available" cabin in Escalante.
    dorunron likes this.
  8. srellim234
    1,198
    1,687
    Laughlin, Nevada
    Thanks for posting that method. It worked after JC's method didn't. I guess different methods work on different cars so it was nice to have both ways to try.
    And yes, you guys are all correct. It did flash briefly earlier in the trip when starting the car but then went right off. The service records show it was exactly that mileage interval since the last oil change when it started appearing.
  9. dorunron
    3,318
    1,103
    Houston, TX
    The method I posted is for Gen II Prius.
    Gen III is different, that is what JC posted.
    Don't know about Gen IV.
    Glad to hear you got it sorted.
    Don't forget about Moab. A nice tourist trap. Spent three days out there on a whim. Nice national park close by, good food, lodging, sight seeing etc.
    Arches National Park - Plan your trip to Arches National Park.
