back seat belt stuck
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by benk33, Jun 14, 2015.
  1. benk33
    benk33 Junior Member
    24
    Austin, TX
    Hi all. I recently purchased a used 2008 Toyota Prius and the back left seat belt is stuck. In other words, if you try to pull the seat belt out it comes no more than a nudge. Is there any way to fix this myself or do I have to take it in somewhere?
    Thanks,
    Ben
  2. Patrick Wong
    18,200
    6,492
    Well, if you are able to remove the trim which hides the mounting hardware then you could replace the seat belt assembly yourself assuming you have the necessary metric tools.
  3. benk33
    24
    Austin, TX
    Can anyone give me instructions on how to remove the trim on the 2008 Prius?
  4. Patrick Wong
    18,200
    6,492
    techinfo.toyota.com
