Back Seat will not lock in up position
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Boojoo007, Feb 18, 2016.
  1. Boojoo007
    Boojoo007 Junior Member
    64
    I folded my back seat down, now it will not lock into the up position! Help anyone?
    I inspected the locking mechanism and it doesn't appear to have anything wedge in there.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Sometimes the rear seat belts get caught between the lock and will cause it not to lock.
  3. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Yeah, I've had that happen. The seat has to move fully back before the little pull-up latches will pop back down again. If there's almost anything at all between the outer parts of the seat back and the body then the seat back won't be able to move far enough for the latches to engage.
  4. Boojoo007
    64
    I'll double check after work, it's possible something is wedged between there.
    Thanks!
  5. Boojoo007
    64
    Thanks guys, I found out the back padding was pushed up too far. My back seat closes now!!!!!!! yay!
