Back to left foot braking
Discussion in 'Gen 2 Prius Main Forum' started by cycledrum, Aug 28, 2010.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ah darn, wish I could free up more legroom to keep right foot braking like I've been for a year or so. Brake pedal is smack in the center and close for me, so it's left foot braking most of the time.
    At least Toyota moved the brake pedal to the right in the 3rd Gen Prius.
    51,141
    what, you only test drove it for a mile and it seemed fine?:cool:
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Nah, I knew it was cramped, brushed it off, but dug the HSD and high-tech displays. Still like HSD.
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    You brake with your left foot?? How would you ever drive a manual?
  5. BDDave
    BDDave New Member
    76
    Iowa
    The brake pedal is on the left side, isn't it? Two pedals, two feet; seems right to me.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Cycle, do you mind explaining why it works better for you to brake with your left foot? I understand that you feel the space is cramped, but I'm not clear how left footed braking helps. I am not trying to be difficult, only curious.
    Tom
  7. Flaninacupboard
    1,297
    213
    Midlands - UK
    In a manual you need to depress the clutch with your left foot at the same time you're depressing the brake pedal with your right foot. Seems like bad practice to use your left foot for braking...
  8. qbee42
    18,058
    3,076
    Northern Michigan
    It's always bad practice to do left footed braking, unless you are doing some sort of advanced racing maneuver.
    Tom
  9. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Sorry guys, I disagree that left foot braking is bad practice. It's quicker and therefore safer. I DO have a brain, however, so when I get into a manual, I use right foot braking, AND I don't press the brake and accelerator at the same time in the Prius.
    It's called adaptability. It's what is supposed to have made us so successful on the planet.
  10. qbee42
    18,058
    3,076
    Northern Michigan
    Studies I have read don't support the assumption that left footed braking is faster. Does your information come from metrics, or your own perception?
    Tom
  11. BDDave
    BDDave New Member
    76
    Iowa
    Of course you can't use your left for braking while driving a manual transmission car; you have to use all three feet then. ;)
  12. bisco
    51,141
    i believe left footed braking is illegal in massachusetts, and the possible cause of some unintended accelleration.;)
  13. qbee42
    18,058
    3,076
    Northern Michigan
    That is the main problem. Left footed braking can be used to good advantage by race drivers and others using advanced driving techniques. The principal disadvantage is that people tend to press with both feet in an emergency, mashing down both the brake and the gas.
    A second, less serious problem is a tendency to ride the brakes during normal driving.
    Tom
  14. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    There have been a lot of studies into this, and the overall finding is that left foot braking increases reaction time and is dangerous. Ask any professional driving instructor he will tell you left foot braking is a practice that has no place on public roads.
    Now, on a track trying to drift through a turn its a different story, but in a mainstream car on a public road, bad idea.
    I too don't understand how cramped legroom makes right braking impossible...
  15. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Left foot braking doesn't really help or make things much better in this car. I'm switching off between right and left foot braking.
    I am more comfortable sitting in and driving my 1988 SR5 Toyota 4WD pickup, but it gets less than 20 MPGs, is old, quite underpowered (4 cyl), came with 31" tires and has manual transmission.
    I ought to sell the Prius in a timely manner because I'm tired of complaining and I would imagine many are tired of hearing it. Bad case of buyer's remorse. I'm in the 8%, other category.
  16. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    It's a perception for me - I look down and see the steering wheel so close to the dash and to my knee while braking. I am 200% convinced the car was not designed for my build.
    I want to enjoy my driving, not just be out there awkward and uncomfortable while driving. I'm in pretty decent shape physically. I run, no back issues.
    I'm pursposely keeping the miles down on the car. I know what to do with it.
  17. SW03ES
    2,480
    176
    Gaithersburg, MD
    Then don't look down ;)
    Seriously, don't brake with your left foot, its dangerous
  18. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I mean look down while holding brake at stoplight.
    I knocked the car out of D gear into B on the freeway yesterday, 3rd time it has happened. I have big hands and that shifter is awfully close to the steering wheel.
    Just waiting for opportune time to sell the car. Not for me.
  19. bisco
    51,141
    you must be on e big fella, big fella. you need yerself a sweet lincoln towncar or something, like kickin' back on the sofa!:)
  20. Flaninacupboard
    1,297
    213
    Midlands - UK
    Yep.
    In all seriousness, did you even test drive the Prius? I've never owned an auto before, so i took one for a four hour drive before buying one...
