Back-up Bulb Fell Into Lens
Discussion in 'Prime Main Forum (2017-2022)' started by bresna, Jun 23, 2017.
  1. bresna
    bresna Active Member
    193
    144
    Southern Maine
    My back-up light stopped working so I bought a replacement bulb and set to replacing it. After several hours and many outbursts of vulgarity, I finally got the bulb holder out. And it was empty! I looked down inside and there was the old bulb down at the bottom.
    I tried like heck to get that sucker out of there but there was no way that was coming out. Then I installed the new bulb and found out why - the bulb barely fits through the hole in the back of the lens. There's no way that bulb is every coming out.
    So I bring it to Portsmouth Toyota. Clearly I need a new lens that doesn't have a bulb rolling around inside it, right? After 45 minutes, the service guy comes out and says that'll cost $588 because someone bumped me which is why the bulb fell out. I said, "Really? I'm supposed to expect a bulb to simply fall out of its socket when bumped?" His answer was that it's my fault and that Toyota would never cover it.
    So I told them to leave the bulb I put in there and give me my car back. I'm not paying $588 for this.
    Boo Toyota. Not happy with this one.
    #1 bresna, Jun 23, 2017
    TonyPSchaefer and Mendel Leisk like this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Along with your brand new car, you should have gotten a "warranty booklet".
    In there, should be a number to call for warranty support at Toyota corporate.
    Use your energy to call them instead of posting in places like this. (y)
    PT Guy likes this.
  3. bresna
    193
    144
    Southern Maine
    Have you ever called that number? I have. An absolute waste of time. I posted here to warn others not to be surprised if they ever find one of their back-up bulbs down at the bottom of their lens assembly. :)
  4. Sam Spade
    2,036
    1,023
    2017 Prius c
    OK, just take the abuse then.
    My second suggestion would be to call your state's Consumer Protection office.......or the Attorney General......but it sounds like you don't REALLY want to get it fixed.
    P.S. You didn't mention if there actually is any evidence of the vehicle being hit in that area; is there ??
  5. bisco
    51,141
    did someone bump you?
  6. bresna
    193
    144
    Southern Maine
    I assume someone did bump me but I've had many cars get bumped and never had a lightbulb fall out of its socket from being bumped. :)
    The service manager came out and told me that they were ordering a new socket. The service tech dropped 2 more bulbs into the lens trying to debug the problem. :LOL: He's managed to get 2 of the 3 bulbs out of the lens but one just won't pull out. So I will have a bulb rolling around in there. I'd rather that than pay $588 to not have it in there.
  7. Mendel Leisk
    40,575
    The original bulb probably wasn't seated fully in the socket, at the factory. I can't see the car being bumped knocking out a bulb: that was a Hail Mary diagnosis by the service department, lol.
    Yeah, I would leave it as-is too. Odd though, that the mechanic can manage to fish some bulbs out, but not all. Was the the one he can't get out the original one, and it's in an odd place?
  8. bisco
    51,141
    idk, if there's no bruise, how can they assume you were bumped?
  9. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Surprised they can't reach it with one of those snake grabbing things.
  10. stevepea
    stevepea Senior Member
    535
    581
    Another option to try is to simply go to a couple more Toyota dealerships and ask them. Don't know where you live, but around here there are Toyota dealerships all over the place. If the Service guy at Dealership #1 doesn't want to do it under warranty, try going to another. They may do it as a "goodwill gesture" to convince you to go there in the future. All I'm saying was, if it was me and it was $600 and it was clearly not right (a bulb falling out?) I'd go to at least 2 more dealerships and give it a try...
  11. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    This makes no since. If the tech had 2 bulbs fall out then the lamp socket is broken and not retaining them. Why not say the socket needs replaced? Unless you have insurance claim level damage to that area how could this be and not be a Toyota defect. This dealer service dept. is BS'n you, go elsewhere.
  12. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    If the bulb is rolling around in the lens, you shouldn't need a new lens. If the lens is removed from the car, you should be able to shake the bulb loose and get it out of the socket or grab it with needle nose pliers.
  13. bresna
    193
    144
    Southern Maine
    They are replacing the socket. They have it on order. I expect I'll be back there next weekend for round two.
  14. bresna
    193
    144
    Southern Maine
    They say it's 90 minutes of labor to remove the lens so I doubt they'll be doing that to get the old bulb out. :)
    As I said above, the socket opening for the bulb is very tight. It's about the same size as the body of the bulb itself. There is no way you're fitting needle nose pliers in there, especially while grabbing the bulb. Also, the lens area is deep so just getting at the bulb is difficult.
    I have one of those "grabber" tools where you press the end of the tool and 4 wires come out to grab stuff. I tried using this for about 20 minutes and every time i got the bulb up to the opening, I just couldn't get the bulb back through that tight opening. No room. The service manager told me that the service tech used a flexible stick with a wad of bubble gum-like substance on it to get the bulbs out but he can't get it to stick to the last bulb for some reason.
  15. bisco
    51,141
    is it warranty?
  16. bresna
    193
    144
    Southern Maine
    They say no. They say it's been bumped so the warranty doesn't apply.
  17. bisco
    51,141
    brutal. how could 'bumping' cause a defective bulb socket?(n)
  18. stevepea
    535
    581
    As I said, try going to another dealership.
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    So......why exactly do you think that the warranty should cover DAMAGE caused by a collision ??
    Hint: It shouldn't.
    And the fact that it has never happened to you (or a few million other people) makes absolutely no difference.
    Maybe you should contact your insurance company.
  20. Washingtonian
    Washingtonian Senior Member
    726
    621
    So.....why do you assume there was a collision? The bulb fell out of a socket that the dealer is replacing because it is defective. Do you think you could hit the car so hard to knock a light bulb out of its socket yet leave no evidence of a collision?
    Prius from Dad likes this.
