Back up camera
Discussion in 'Gen 2 Prius Accessories & Modifications' started by RestedSoul, Dec 10, 2016.
  1. RestedSoul
    RestedSoul New Member
    Tennessee
    so I've been told by the dealership that the 05 does not come with the camera. There is a place for it. Just wondering if all the wiring is there, and if I get one off of another vehicle if it would just plug in and work. Just trying to get all options that I can on the car. Just bought the car two weeks ago.
    Miguel Olivares and kenoarto like this.
  2. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    I would also like to know the answer to this
    Question.
  3. Rocket Man
    Rocket Man Junior Member
    37
    Denver
    Guys,
    Unfortunately, the '05 is not wired for a backup camera
  4. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Please, what are the options available to add a back up camera to an 05? Will the nav- head unit accommodate an add on b/u?
  5. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    There was an expensive interface that would allow an add-on camera to be added to your existing MFD (Search for "Lockpick"), You can change the MFD to a 2006 or later and do a bunch of work and rewiring and use either an add-in camera or the OEM Look here: Wires connection of back-up camera to MFD !!! at the work @DangNabbit and @OBJUAN are doing), but the easiest would be to replace the radio with a modern one with a screen, and get a license-plate add on camera.
    #5 ITBland, Aug 20, 2018
    James1964 likes this.
  6. MagnusAG99
    MagnusAG99 Senior Member
    672
    518
    Norway
    Just buy an aftermarket camera and/(or not) screen, the OEM camera on the gen 2 prius sucks when it comes to quality, same does the gen 3, u will get both a wider lens, higher FPS and better overall quality with aftermarket even if u buy one for just 8 dollars.
  7. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Thanks guys! Very helpful.
  8. ITBland
    433
    272
    Even though there is a "place" for the camera, the cutout in the sheet metal is missing AND there is no wiring. If you have 2004 or 2005 with navigation, the MFD uses RGB video, all of the cameras are composite video.
