Backed bumper into a trailer hitch, do I have to fix this? (possible rust issue)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pripripewpew, Oct 10, 2014.
  1. pripripewpew
    pripripewpew Junior Member
    Springfield, VA
    P1010998.JPG my wife backed my baby into a parked trailer, and punched about a 5 in x 3 in hole in the back bumper. It's on the "crease" where the bumper transitions from vertical to horizontal, pics attached.
    My concern is that rain water will come straight in from the top side of the hole and collect inside, possibly causing problems. The metal is what the plastic bumper is up against, so i'm guessing it's the frame, and protects your rear end during a collision.
    If I don't fix it, might I run into problems?
    I'm trying to save money, not buy a new bumper, but if the risk outweighs the savings, then I'm gonna suck it up and replace it.
  2. jaymac
    jaymac membore
    179
    56
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    I would take the bumper off and do a fiberglass repair from the back side after massaging the broken piece back into place. Then smooth the seams of the break on the outside with some grey silicone.
    John
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    If it's "your baby" then fix it right.
    If you just want to save money?
    Many ways to seal it up and negate any rain water risk.
    Do it right...or Get Er Done...your choice.
  4. Mendel Leisk
    38,726
    Maybe time to stop calling these things "bumpers".
    Okinawa likes this.
  5. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    Duct tape will fix anything... (y)
    ...and almost an identical color match.
    jk
    In all seriousness, I haven't had the rear bumper cover off and am unfamiliar with what's underneath. If you are just looking to create a waterproof seal, a good quality silicone glue would work to that effect. Also, using a hair dryer(recommended) or heat gun and a little elbow grease will help with the removal of the creases in the plastic cover.
    #5 sfprankster, Oct 10, 2014
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Water (and any salt contained therein) will splash up inside from underneath. I don't think it's a rust issue, just cosmetic.
    And yes, it's a "bumper cover". Not really sure there's a "bumper" under there. There isn't on the FJ Cruiser.
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    If not sealed properly, the eps foam energy absorber between the bumper cover and the aluminum bumper will deteriorate and lose it's energy absorbing properties.
    SCH-I535
  8. mrbigh
    3,686
    699
    Long Island, NY
    #8 mrbigh, Oct 11, 2014
  9. CapeAnn
    CapeAnn Member
    114
    25
    Northeast United States
    I recently got my Pri back for a destroyed cover, bumper frame and other - there is a metal strut under the cover with some foam. The cover itself (new) was listed at about 900.00. Here's the thread and the pics are near the end of page 1.
    Collision repair advice | PriusChat
  10. si12j12
    si12j12 Member
    64
    There won't be a risk of rust , the area right behind of it is foam and aluminum beam . There is no exposed of bare metal. So no. But sure looks ugly...
    Best bet is to search craigslist or other places to get a good condition used replacement (if budget is an issue)
  11. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    Try rockauto.com. Get it painted then install.
  12. Mendel Leisk
    38,726
    It might be better to install, then paint. And extend the paint a bit into adjacent body panels, what they call blending, where they gradually thin out the color coat. Frustrating to have to repaint half the car, but that's actually the best way to avoid an obvious transition.
  13. riceroni87
    360
    598
    Oxnard, CA
    What he said^
    iPhone 6 ?
  14. The Electric Me
    9,083
    5,798
    True.
    Guess I'm old enough to remember when bumpers were designed to absorb an amount of impact, and continue on....
    Todays "bumpers" are designed to absorb impact....then need to be almost entirely replaced at great cost.
  15. Mendel Leisk
    38,726
    I don't think they're even designed to absorb impact, likely the body crumple does that. They're largely "fairings", in my estimation. The 3rd gen rear bumper can barely hold itself in place, there's been a lot of saggy butt reports, lol.
    Our first car was an '81 Civic. It had a chromed steel wrap-around rail, with a wide, black rubber wear strip at it's equator, it was mounted on two shock asbsorbing horizontal shafts, bolting into the frame.
    Our next car, an '83 Accord I think, had switched over to the fairing style, but at least it was unpainted black plastic, poorly mounted, with a pebbly texture. At least it could take a minor ding without showing too much.
    Todays bumpers are ridiculous glass jaws.
  16. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I recommend a bit of aluminum like this[​IMG]
    iPhone ?
  17. riceroni87
    360
    598
    Oxnard, CA
    Oh here come the prius memes
    iPhone 6 ?
  18. Roland1555
    Roland1555 Senior Member
    282
    68
    Vancouver BC
    You might get away with using the stick on rear bumper cover that is an OEM accessory.
    It is black plastic and covers most of the hole, but might need a little artful extension along the bottom edge to fully cover.
    I am thinking along the lines of the black material they use to line in pick up truck beds. Fit the plastic cover before removing the double sided sticky tape to see how much further you need to cover with the spray on stuff, mask and see.
    Roland
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Good thing the trailer tongue didn't hit the hatch or you'd be looking at a bigger repair.
    My concern wouldn't be with water getting in the hole but rather with hatch wall having paint damage around that dent & getting rust
    You could do 1 of 3 things:
    1) Buy a new bumper cover and have it painted
    2) Buy a used bumper cover in the same color
    3) Buy a used bumper cover any color and have it painted
    If it helps, I have a 2012 blizzard pearl rear bumper cover that I can sell you.
    iPad ?
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Having replaced my rear bumper cover twice I can say without hesitation do not buy the $100 bumper cover. The plastic is so thin it looks pretty bad on the car. I went that way the second time and highly regret it. Buy a good condition used bumper and take it to a body shop and its $150 to have it painted. Must be painted off the car.
    It looks very much like a G2 bumper which is fairly easy to take the rear cover off and uses alot of clips along the bottom that may break off when you pull the cover off. Buy new clips online before hand.
    All in maybe $250 which may be cheaper than your insurance deductible.
