Backseats loose?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nemrut, Aug 27, 2009.
  1. nemrut
    nemrut New Member
    57
    san francisco
    I just had leather installed and noticed that my back seats although secure, seem to be move a little when i lift up the bottom edge of the seat. Anyone else notice this?
  2. DavidA
    2,328
    1,812
    Chicago western burbs
    Who did the leather seat install? Dealer or 3rd party?
  3. mccats
    mccats New Member
    44
    Midwest USA
    Sounds like you need to visit your installer to ask them whoever that might be.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The rear seat bottom has protrusions that "snap" into holes in the floor. There are no fasteners. If you pull up on the front of the seat bottom it will come loose and you can remove it. Be aware, if you do this you will have to position the seat belts correctly before re-installing the seat bottom.
    It's possible they got some leather in the way of the posts. Pull the seat bottom out to have a look or have the installers check it.
  5. nemrut
    nemrut New Member
    57
    san francisco
    The Dealer sent it out to a leather shop they frequently work with.
  6. shaunj
    shaunj New Member
    22
    Maryland
    How much for the leather seat upgrade?
  7. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    bumping an old thread -- my left rear seat bottom is loose for some unknown reason -- I was removing my backpack from behind the drivers seat and I noticed the seat bottom came up very easy -- I see where its attaches to the floor but it doesn't seem to want to latch back in securely and still seems loose.
    anyone with a clue??????
  8. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    There is a plastic female 'clip' that the seat snaps into. This has a lip that snaps the seat in, and holds it. This is broken.
    You may be able to pull out the seat, take that part, and bend the latch back.
    Dealers don't stock these (takes a day or two). Cost is like $3.
    2 people like this.
  9. bagwell
    592
    49
    the woodlands, tx
    you are correct sir!
    I removed the female part - which is actually 2 parts - the inner piece was broken and I superglued it. We'll see how long that fix lasts.
    thanks.
