Backup camera - Any way to restore?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Jan 4, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    292
    44
    Virginia
    After I totaled my 2009 Prius, I replaced it with a 2006 with remote start and backup camera.
    Bought it for 3150 total. Maybe I could have gotten a better deal but likely not a bad deal.
    I know my roommate's Prius reverse camera is not great. Mine seems okay but need to see in different lighting conditions.
    Is there any way to restore the lens without replacing the whole camera?
  2. Tombukt2
    Tombukt2 Senior Member
    11,999
    2,121
    Durham NC
    Yes the last time I bought one of these things and all that I I took some of that stuff you use on headlight lenses and all of that plastic restore I think it was McGuire's and a white bottle and I put some of that on a rag and rubbed it over the lens I don't know for about 5 minutes made a huge difference The next time I had the stuff out I had my little buffing wheel on my electric motor like a Dremel and I buffed it and it seemed to do very well. And then there are some models that have better cameras than others I'm not sure if this is a year thing or how this works but I've noticed that if I get the MFD and/or the camera off of fairly loaded generation to like one that has the GPS and all of that upper level trim the backup camera seems to be better definition or something I don't care what it is but it looks better so I've done that a couple of times taking the camera off of a loaded vehicle and put it on my '07 or '09 or even my '05 which weren't base cars but they weren't the full ride and then in another car I changed the MFD to the one that's well above a base and even had better video from my rear camera which was from the factory on the upper level MFD so I'm not sure what's going on there I don't think there's anything wrong with any of the components but maybe something got changed in the middle of the generation 2 model or maybe not and then you can add aftermarket cameras I think if you pay attention that'll even display on our MFD Just realized that our MFDs are not that high of a resolution so getting a super high resolution cameras not going to really help you on the factory MFD if you replace the stereo with one of those clarion's or whatever You can get a backup camera the 1080p practically.
  3. Leadfoot J. McCoalroller
    7,827
    7,292
    Pennsylvania
    2018 Prius c
    you can polish it- more or less the same materials and technique as one would use for headlamp restoration.
  4. Paul Gregory
    Paul Gregory Senior Member
    1,368
    356
    Alberta
    2024 Prius Prime
    XSE
    I tried polishing my Gen 3 backup camera lens because it became foggy after 11 years, but it didn't work. I gave up and tried to replace it.
    To escape the $600+ cost of a genuine replacement, I tried 3 different third party cameras from Amazon and elsewhere. None of them worked, despite 3 different experts working on it.
    Sure glad I sold that car. The new owner didn't seem to have a problem with it.
  5. KitsuneVoss
    KitsuneVoss Member
    292
    44
    Virginia
    I think I would just live without the camera in such a case
  6. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Wash it thoroughly with some Dawn (or equivalent) and water, with at most gentle pressure, before trying to buff it. All the grit that might be on it has to come off first or any attempt to clean the lens that involves a lot of rubbing motion (by hand or machine) will scratch it badly.
