Backup camera image hard to see in bright light
Discussion in 'Gen 2 Prius Audio and Electronics' started by Andy F, Apr 28, 2024.
  1. Andy F
    Andy F New Member
    Maryland
    I have a 2006 Prius. The backup camera is becoming harder to see in bright light. It is also somewhat less powerful at night. I wonder if the primary problem is the screen becoming dimmer with time or if a replacement of the backup camera might make a significant difference. I wonder if others have had this problem and know the answer to this question (and perhaps have fixed the problem). Thanks!
  2. Tideland Prius
    16,125
    It’s more likely the screen than the camera. You can adjust the brightness and contrast in the meantime (press Display then General then adjust the brightness and/or contrast. I think there’s also a Camera section for adjusting the brightness and contrast when the backup camera is on).
  3. Andy F
    Andy F New Member
    Maryland
    Thanks! I will look into that.
  4. pavidco
    pavidco New Member
    Tehran
    Your 2006 Prius sounds like a trusty companion! It's a bummer that the backup camera isn't as clear as it used to be, especially in bright light or at night. It's totally natural to wonder whether it's the screen dimming over time or if swapping out the camera could make a big improvement. Have you heard from other Prius owners who've experienced the same issue? They might have some valuable insights or even solutions to share. It's always nice to learn from each other's experiences!
