Backup camera on 2013 Prius C Three
Discussion in 'Prius c Accessories and Modifications' started by HilCountry, May 5, 2015.
  1. HilCountry
    HilCountry New Member
    Colorado
    hello,
    I am in a process of buying a 2013 Prius C three and my goal is to put in a backup camera after. Dealer says it doesn't have the GPS but it has the larger screen. i've attached a picture of it. I thought GPS was a standard feature in 2013 C three.
    Will it still be possible to add a backup camera in it without the gps unit? Do you have to have GPS to install the backup camera?
  2. NR427
    NR427 Member
    142
    100
    Utah
    Not sure about adding a camera, but this car has gps. I wouldn't trust what the dealer says.
  3. HilCountry
    Colorado
    how can you be so sure? is it standard on c three?
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    You'll have to buy a rear camera input harness. Also the power for the camera from the harness is 6V not 12.
  5. HilCountry
    Colorado
    Thank you. So do i need the gps in it? the dealer says it is not there.
    This will be my first toyota and prius c. Is there any place i can find the options that was available 2013? I wanted to be sure of what 2013 Prius C Thee had as option and this particular one has everything necessary to install a backup camera.
  6. Motov8r
    Motov8r Member
    102
    There is a great back up camera thread in the audio and electronics prius c forum. Check that thread. For 2012 and 2013 you do not need a harness if you get the right kit. It comes with a 6v camera. Check the thread for links to various camera solutions.
    iPhone ?
  7. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
  8. NR427
    NR427 Member
    142
    100
    Utah
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
