Backup camera quality
Discussion in 'Prime Main Forum (2017-2022)' started by PiPLosAngeles, Jun 26, 2020.
  1. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    This is one of those things that makes me slap my forehead, but it took me 18 months to realize that the contrast adjustment for the backup camera is backwards. All this time I was bugged by the lack of contrast and washed out picture. I kept trying to turn the contrast up by pressing the "+" and moving the slider to the right. I only recently noticed that this decreases contrast. Turns out pressing the "-" and moving the slider to the left is what increases contrast. Who knew that "+" meant "less contrast"?
    Dave deBronkart likes this.
  2. schja01
    schja01 Senior Member
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Does that mean if you press a color you get the Complementary Color instead? ;)
  3. Washingtonian
    Washingtonian Senior Member
    726
    621
    The first month I had my car I took it back to the dealer complaining that the back up camera image was only on half the screen. They finally figured out that was how Toyota designed it. I still think it is silly to have an 11" screen and only use half of it.
    Mambo Dave likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You would need a camera with matching (or higher) specs to fill that screen, otherwise it would look even worse (pixelated).
  5. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    I think additional vertical resolution would be of minimal value for backing up unless you wanted to avoid backing into low flying aircraft. Had the screen been horizontal a wide angle camera would definitely been if value.
    EyePrime and jerrymildred like this.
  6. Washingtonian
    726
    621
    As we know, cameras have been improving over the last few years. I am amazed at the quality of pictures I can get from my iPhone compared to the expensive Lumix camera i have. We were talking about the blind spot monitor on the Prime. It is interesting that the Tesla Model 3 can use their rear camera while driving down the freeway to act as a blind spot monitor to see oncoming traffic in the next lane. It would be really great if there were a front camera mounted low that would let me know when I am getting too close to the curb as I drive into a parking spot. There is no doubt that what we have will be improved in the near future. I hope it will be incorporated in the next RAV4Prime.
    Ferretguy likes this.
  7. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Front facing camera would be appreciated. The radar sensors don’t do a good job of detecting low objects like curbs and the like. Would make pulling into parking spaces easier which is why I back into spaces whenever possible. I find it easier (in my advanced years) to pull out of a perpendicular parking spot safely if I’m facing forward.
    Tips likes this.
  8. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    It would be difficult to fit landscape orientation camera image to full the portrait screen without severely distorting the image.
    EyePrime likes this.
  9. Washingtonian
    726
    621
    I am not sure why that is. I have an iPad that is about the same size as the Prime screen. I can press the camera button and get a clear full-screen picture whether it is in portrait or landscape mode. What is so special about the 11" screen in my car that it can't do that?
  10. Salamander_King
    11,024
    8,970
    New England
    I don't think that's a good comparison. On iPad or smartphone, you are changing the orientation of the image when you rotate. If the camera source has a fixed landscape aspect ratio, you can't fit that into portrait orientation without distorting the image. It's similar to landscape photos or videos displayed on the portrait smartphone screen. If you want to see the entire photo without distorting the image, you will have wide black bars. If you want to fill the entire portrait screen with a landscape image without distortion, the only way is to crop the image which will serve no purpose for a back-up camera.
    jerrymildred likes this.
  11. PiPLosAngeles
    1,551
    724
    I'm not trying to be obtuse, but I never understood why backing into the spot feels easier than backing out of the spot. I mean you have to backup at some point, why is one direction more or less difficult than the other?
    I've heard it said that there's the danger of pedestrians and cross traffic backing out, but I see people backing into spaces have issues with pedestrians and cross traffic too.
  12. Elektroingenieur
    2,515
    3,287
    Three Touring
    It’s more about safety than difficulty: it’s best not to back up at all, but if you must choose between backing in or backing out, it’s safer to back in: you can check the parking space beforehand, and you’re less likely to have a collision with a pedestrian or a moving vehicle.
    The Bell System explained it better than I can (starting at 3:46 and 6:36):
    (@ETC(SS), are they still using the same video?)
  13. Johnk989
    Johnk989 New Member
    It’s like you said, danger of backing up into cross traffic or pedestrians. There are much fewer variables when backing in to an empty space then when backing out. Also makes for a quicker getaway. In most cases I find it better to back in, but there are exceptions.
    BackIng in is definitely an advantage if traffic is backed up in the parking area. Like during an evacuation. It’s no fun trying to back up into a line of cars where everyone is trying to get out as fast as possible.
  14. PiPLosAngeles
    1,551
    724
    What makes a pedestrian or cross traffic less likely to be behind your car when you're backing into a stall versus when you're backing out? That's the part I don't get. People walk/drive behind me backing up all the time, even trying to back into a space. Sometimes I feel like they do it more in that case, maybe because they don't expect me to stop and start backing.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Where I work they want us backing into spots and one of the reasons why is you know what you're backing in to whereas you do not know what you might be backing out in to;).
    Another reason is if you need to leave suddenly, you can simply pull out and leave:).
    I usually look for pull through spots but if I can't find one readily, I will back in due to training(y).
  16. ETC(SS)
    7,379
    LOL
    No...We no longer use that specific video.
    Even MY beloved company has to change out their training vids every quarter century or so.
    HOWEVER (comma!) Big Phone still follows the same practice.
    When they started issuing techs those little “Hello Kitty” vans there was a spike in mailbox murders, but usually the standard 3-day unpaid vacation followed by a 3-year service record entry incentivizes techs not to squish things.
    About once a month I’ll be parking Goofy and putting out three cones and somebody will ask me if I’m afraid somebody will run over my little car.
    Like face masks......I use it as a coachable moment.
    #16 ETC(SS), Jun 27, 2020
    Elektroingenieur likes this.
  17. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    A caveat regarding backing into a space as opposed to nose first, is that steering may be more challenging for some to gauge turning radius effect and proximity to confining adjacent vehicles (think rear-steering over control as with a forklift). Here, the back up camera and proximity sensors can be quite helpful. Conversely, backing out into an open travel lane is not so much a harrowing experience when equipped with the Rear Cross Traffic Alert.
  18. schja01
    1,851
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Why does the automatic parking feature (if you have the feature) only offer back in perpendicular parking and not the opposite?
  19. PiPLosAngeles
    1,551
    724
    Weird. My work is the opposite. If you back in to a space you will get your parking pass revoked. Mostly because people in general aren't very good at driving in reverse and they block the circulation while they try and maneuver into their spot. Waiting 20+ minutes just to exit a parking structure while you wait for 10 different people to perform the maneuver can be exhausting all by itself.
  20. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    Given the large display and a tiny portion of it is used for the backup camera, Toyota could have displayed other information on the bottom half such as distance to object data from the sensors. If the bottom display showed your car from overhead and either showed distance to object from each side of the car or at least display those bars, it would be somewhat helpful.
