Backup camera question
Discussion in 'Gen 3 Prius Audio and Electronics' started by Yiannifun, May 26, 2011.
  1. Yiannifun
    Yiannifun New Member
    Athens, Greece
    I never had a backup camera
    I wonder if the image you see in the rear view mirror will be the same in the screen. I mean, if you see a red car behind you, and on the right in the mirror, will it be on the right at the screen too, or it will be the original signal from the camera showing the non invertet image? This will be a trouble for me...
  2. Mendel Leisk
    38,647
    Try looking behind you, then at the image. You should be able to sort it out ;)
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The camera displays a mirror image, just like that in the rear view mirror. It does this to avoid confusion.
    Tom
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You could flip the pic upside down if you were so inclined. Just don't fall up when you stumble out of the car.....
  5. snakeye2669
    snakeye2669 Junior Member
    Jersey
    It display the same image as if you turn your head around to watch the rear with your own eyes. If a object coming from the right side, it will be coming from the right side on the back up screen.
