backup camera rough in
Discussion in 'Gen 3 Prius Audio and Electronics' started by whitedogone, Jul 6, 2010.
  1. whitedogone
    whitedogone New Member
    50
    IL
    I am installing my wife's new JVC nav tomorrow. I want to add a BU cam but don't have it yet. As I have read most that have installed them needed to add an extention to the RCA cable. I want to add this so that I can put everything back together and not have to take it apart again. That said: what length extention do I need, where should I "end" it for now , and will I need to rough-in any other wires from the head unnit to the cam?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I just finished my install and I needed a 4' (or whatever the standard RCA lengths are) extension. I ran it down just behind the brake pedal area to meet up with the cable from the cam at right behind the parking brake.
    The other wire you can put in now is the reverse trigger. I ran mine from the left rear taillight. It would have been handy finding a source @ the dash. Perhaps the fuse for the reverse lights?
    Have fun!
  3. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I'd run a 12 foot cable - I think it would make it to the drivers door panel.
    The Ebay cameras mentioned elsewhere fit well...
    Put your mic above the drivers A pillar - or at the overhead console.
  4. rrolff
    1,610
    246
    So Cal
    Edit: I would add if you know where thebackup wire is up front - wire it now - but if you can't find it (I couldn't), you may want to run an *extra* wire to the backup of the JVC (12 foot also). I picked up the 'reverse' from the reverse light at the tail assembly. So I ran another wire back.....
  5. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
