'Backup' Hybrid battery?
Discussion in 'Prius c Main Forum' started by farmecologist, Jul 15, 2021.
  1. farmecologist
    farmecologist Senior Member
    1,960
    1,800
    Southern MN
    Hi all,
    I was poking around our local junkyard sites and came across a Prius C hybrid battery for an extremely good deal. The donor Prius C had 65K on it when the battery was pulled. However, the guys at junkyard said it has been 'on the shelf' for a bit over 2 years.
    I'm not too familiar with battery recycling, etc...Can you battery experts out there give me advice on what would need to be done to get the battery in working order? I'm assuming the cells are fully discharged by this point...correct? If so, is that bad?
    Note that the battery on our 'new to us' 2012 Prius C also has 65K or so but being a 2102, the battery is getting old...and I know that age may matter more than miles for these batteries. So I thought it might be good to have a 'backup' battery for the inevitable...
    Thanks in advance! (y)
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Our v is a '12 with 30k miles roughly. I don't think it's the age, it's the mileage. 65k is a little high. I'd wait until I need one then buy one of the available options...
    moto g(7) power ?
  3. tangerino
    tangerino Junior Member
    82
    16
    WA
    I would check the voltage if you can. From what I've read if any of the blades are anywhere near 6V out or below each then they're probably permanently damaged. I'm curious how much they would self discharge but if 0.1v/month then they're probably dead. I read they shouldn't sit longer than 6 months without recharging.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Sitting two years is bad for NiMH batteries. I wouldn’t worry. Just keep driving the C, I doubt you’ll have any battery problems till years down the road.
    My sisters highlanders hybrid battery is 16 years old and works very well. Wild how well these batteries hold up in some cases.
    douglasjre and farmecologist like this.
  5. bisco
    52,404
    some things are just not worth trying to maintain for an emergency. this is one of them.
    when your battery goes out, get a new one
    jzchen likes this.
  6. farmecologist
    1,960
    1,800
    Southern MN
    Interesting...ok sounds good. Hmm..I hadn't heard that dead cells couldn't be brought back to life. Also reading about replacing cells yourself. Looks kind of interesting for a guy like me that likes to tinker. (y)
    I'd be interested in hearing from other battery gurus...especially the ones that have replaced cells, etc... I swear I've read some posts about people slowly recharging dead cells and they work just fine. However, of course I can't locate the threads on demand right now.
    @Mendel Leisk @Raytheeagle any idea on who some other 'battery gurus' are that could chime in here?
  7. Mendel Leisk
    41,925
  8. farmecologist
    1,960
    1,800
    Southern MN
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    @SFO has rebuilt battery packs with the Prolong equipment before:).
    But that excludes reviving a dead cell:whistle:.
    Best to just swap that out and balance the pack ;).
    I'd start by measuring individual module voltages and see where you stand if you are set in purchasing the spare pack (y).
    farmecologist, Mendel Leisk and SFO like this.
  10. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Resident librarian :).
    He's got us covered(y).
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    farmecologist and Mendel Leisk like this.
  12. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi farmecologist, I’d buy it if it’s a great deal, you have the money to spare, and you want to learn first hand all about these batteries, cells, modules, blades. You’ll learn a lot, not be under pressure to change the good battery in your running car.
    If you’re successful you can then look around for a deal on a car with a bad battery, and flip it. Or keep it as a back up car.
    The gear to discharge and charge these batteries either as a unit or as individual modules is inexpensive and readily available.
    Aloha
    farmecologist likes this.
  13. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    This list could quickly become quite extensive..
    How about a few of the peeps on the other side, like @dolj and @Phildo - or the missing in action @kiwi ?
    And though Steve Keith (Phoenix Hybrid Batteries LLC) isn't currently around (sigh), let us not forget :whistle:
  14. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    I don't see the point of aging two batteries instead of one.
    Invest the money somewhere safe and buy a good fresh battery the day you need one. The one you have may still give years of good service.
    Compound interest ages better than NiMH batteries.
    dubit and Aaron Vitolins like this.
  15. farmecologist
    1,960
    1,800
    Southern MN
    It is an extremely good deal.. I think the yard is pretty motivated to get rid of it.
    However, the fact it has sat on the shelf for 2 years or so seems pretty concerning based on a comment in post #3 ( 'Backup' Hybrid battery? | PriusChat ). If the battery modules are truly discharged, then I'm not sure it's worth it? What I want to know is if discharged modules can be 'resurrected' or not. Appears not...but I'd like some experts to chime it. (n)
  16. bisco
    52,404
    there's a thread here somewhere about reliquidating them
  17. farmecologist
    1,960
    1,800
    Southern MN
    Interesting...I haven't found it yet. Any idea where it's at? (y)
  18. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    This thread will get you started : Re-hydrating the battery modules. | PriusChat
    Would've poked the bear directly, but he is already spun up elsewhere ;)
    Raytheeagle, bisco and farmecologist like this.
  19. bisco
    52,404
    thank you sfo!
    Raytheeagle and SFO like this.
  20. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    If fully discharged (0V) then no. If at least a few V then maybe (the more the better). Check the voltage of each cell and decide from there if it's worth your trouble and money.
