Bad audio after accidental full volume blast
Discussion in 'Gen 2 Prius Main Forum' started by jonhatting, Sep 29, 2018.
  1. jonhatting
    jonhatting New Member
    Laguna Beach, California
    I'm new to this chat as I just got a 2007 Toyota Prius as my first car, but if someone could help me understand what's going on with my audio, that'd be great.
    Long story short, I had an accident when turning the car on, resulting in the volume being maxed out with audio playing from my iPhone. Ever since then, I get weird crackling noises at certain frequencies during a song. I'm not sure how to explain it, but it's a buzzing at certain tones. I'm not sure if this has always been there, I've just started noticing it after this encounter.
    I've tried EQ but that doesn't make a difference, but one thing I noticed is that the weird cracking plays through all speakers, which I've accomplished by moving the sound around to only play through each individual speaker, with the same noise through all of them.
    Could it be the JBL amplifier that's bad, or is the sound system in these cars just like that?
    Thought I'd mention that this is the Premium JBL system with NAV. Everything is stock.
    Thanks for helping me out!
    johnerh likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You blew your speakers. You are going to have to replace them to fix it. Speakers are actually quite nicer now than the old ones.
  3. PriusCamper
    PriusCamper Senior Member
    11,190
    4,560
    Pacific Northwest, USA
    Hmm... I used to be in the car stereo installation biz in my younger years and that's a new one to me. Usually your symptoms can be explained by one of the speakers blowing out, but never heard of all of them blowing at once? I guess that's possible?
    The basic concept is the smaller in power & quality your amplifiers the more likely you can damage your speakers. And while you can have a huge amplifier and blow out your speakers from too much power that's much more rare. Kinda like how a healthy 12v battery runs almost forever in a Prius, but soon as it's charge goes down all kinds of anomalous error codes can get thrown.
    But in general, it would make sense that your problem exists prior to amplification, like somewhere in the pre-amp circuit, but that doesn't make sense because it's not where things go bad when the volume is turned up too loud.
    To completely discount that all speakers didn't blow at the same time, pick whichever speaker is easiest to remove and plug in a different speaker, most any kind of speaker, to confirm the noise is still there.
    If it is still there, the next step would be to pull out the deck and tap into pre-amp outputs with headphones to see if the problem can still be heard. If that's not where the problem is, then the problem is in the amplifier. If it is where the problem is, you'll need to replace the car stereo or have it taken apart and repaired. Of course, I've never looked at my '07 stereo, so it's possible that the amp and stereo system are all inside the same box, but most likely the box will have pre-amp outputs on the back for upgrades. They almost always do. Usually there's a wiring diagram on the deck, but again I've never seen my car's deck, so not sure.
    If I had to guess... I'd think that is was time to start shopping for a new stereo for your car. But try above steps to be sure....
  4. PriusCamper
    11,190
    4,560
    Most OEM stereo components are well matched and incredibly difficult to damage at full volume... But certain types of music, especially really solid sound wave synth music like dub step, or anything with sub-harmonic effects can blow speakers out regardless of design. What kind of music was on when the damage occurred?
  5. Skibob
    2,912
    1,496
    Northern California
    I would agree normally but the speakers are 11 years old. That’s a long time for the foam surrounds to rot
  6. jonhatting
    Thanks for all your replies.. In answer to PriusCamper, It was actually lo-fi hip hop (a type of jazz) so nothing like heavy metal...
    I should also mention that this doesn't happen with every song, which leads me to believe that it could be the amplifier not being able to pick up certain frequencies and ends up just giving me a buzz. Could it just be a bad stock amplifier?
  7. PriusCamper
    11,190
    4,560
    Yes, but it's also likely that the deck and the amplifier are inside the same box... Of course, if it is only the amplifier, you can use the pre-amp outputs to bypass the bad amp and put a new amp under the seat or somewhere else. Probably a good idea to upgrade your speakers with ones that are higher quality better match to the new amp too. Also running new wires was always a standard back in my car stereo days, because OEM wiring harnesses are designed to keep costs to a minimum, not provide high quality
  8. jonhatting
    Makes complete sense. I would like to upgrade the speakers and amplifier, but keep the stock head unit. Is that possible? Also, I know nothing about car audio... would I be better off learning how to do it myself, or should I just take it to a local. I know a few people who are reasonably priced and have done excellent work for friends.
  9. johnerh
    johnerh Junior Member
    45
    Los Angeles
    What did you wind up doing in the situation? I have an aftermarket head unit, but no matter how I try to adjust the equalizer settings there’s still crackling and distortion at loud volume. If I minimize the 60 Hz option, then the sound sounds pretty darn good, but not perfect. If I just need to replace my jbl amplifier, which one should I try?
  10. mr_guy_mann
    mr_guy_mann Senior Member
    3,529
    1,611
    NJ-USA
    No idea, but are the speakers themselves ok? I might think those would cause problems sooner than the amp.
    Could be wrong, but old OE speakers...
  11. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,806
    Texas Hill Country
    Exactly... or the aftermarket head unit is overdriving the JBL amp.
