Bad Axle Gen4
Discussion in 'Gen 4 Prius Main Forum' started by JObe, Mar 21, 2020.
  1. JObe
    JObe Junior Member
    17
    Ventura, CA
    I've had a clicking noise from the front when I apply brakes, asked dealer to check it during my routine service (certified pre-owned, warranty service for 12mos). 35k miles on 2016 Prius. Turns out front left axle was bad, they replaced (1.7hrs) under warranty. Is this normal? Do Prius axles go bad? I've had car for 3months, approx 7k miles. I'm new to the Prius world. TIA
  2. priusman09
    priusman09 I used to be a TDI
    67
    76
    wisconsin
    My 2009 had no issues with axels in 225,000+ miles. I did do a front wheel bearing at 110k and the second at 187,000. Come to think of it.....those were the only 2 repairs I had with the car- Period
    pjksr02 likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Search PRIUSCHAT - I recall maybe ½ dozen reported.
    JObe and Elektroingenieur like this.
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    JObe and alanclarkeau like this.
  5. JObe
    JObe Junior Member
    17
    Ventura, CA
    Perfect. I searched before I posted, didn't find that thread. Just finished reading through it, it thoroughly covers my issue. Thank you!
  6. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I had my 2016 prius axle replaced twice, one at 35k and one at 60k. I believe most people don't hear it if it does occur and someone with three other prior priuis's said his all did it, but caused no issues in previous models. This is my first Prius and I noticed it. So far cross my fingers the noise has not yet returned the third time but this issue is only covered to 60k under factory warranty.
  7. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    SW Florida? I know the Bradenton/Sarasota rather well, I don't recall road surface issues (potholes, expansion cracks) Any idea why your car would have 2 failed FE axles? One on each side, or on the same side?
    OEM 15"s?
    I've just scanned the 13 page "Clicking sound on regen braking" thread. Any idea if Toyota changed CV joint vendors, or perhaps they changed the quantity/quality of the CV joint lube?
    Thanks!
  8. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    What is not normal is when you say clicking noise happens. CV joints in my experience and commonly known to click during turns not breaking. Could be mechanics takeing advantage of warranty. NOT the first time I've seen this. I knew some dealer mechanics that would replace a fuse and tell manufacturer it was shorted wire and dash had to come apart.
  9. pianewman
    264
    183
    2018 Prius
    I don't have this problem, but I'm a proactive (neurotic/OCD) car owner who likes to learn/know about possible weaknesses.
    I agree with you that normally CV failure/clicking is noticed while turning. In the extensive thread about this, someone(s) mentioned the possibility that the regen braking causes a different kind of torque to the shaft. It sounds sketchy to me, but maybe it's possible?
    I'd like to know what part of the axle assembly is making the sound? Is it actually the CV joint?
  10. Raphael Muscarelle
    661
    222
    The CV joint itself. There is caged ball-bearing fixed to the shaft then slid into sized channels on end piece. The channels and bearings ware and then start clicking.
  11. robsnyder20
    378
    302
    SW Florida USA
    I drive pretty easy in the SW florida area (no real potholes issue here). Normally back and fourth on US41 for roughly 30 miles each way for my commute. I wouldn't say its a failure but more of a noise that wasn't there before and I am proactive and notice odd noises ahead of time. Most of the mechanics wouldn't even hear it till I recorded the noise on my phone and cranked it up in the car (took several visits both times to get them to do the repair). I can say it makes more of a whirling sound now than when it makes the clicking noise. Now that I am out of warranty I can say I am not going to pay the $800 to get it fixed anymore unless there is a real failure of the axle itself. FYI the clicking noise does NOT occur when shifting into neutral and using friction brakes.
  12. pianewman
    264
    183
    2018 Prius
    Continued clarification is appreciated. Still speculating if Toyota changed vendors, if they modified the design (not likely, except maybe specified harder steel from the vendor?), or have installed a thicker lube, which would dampen what seems for some to be a naturally occurring clicking? Curious minds want to know...
    If this is simply an axle/CV replacement, an indie shop should be able to do the repair for about 1/3 what your dealership is charging...IMHO, of course. (I haven't examined the drivetrain, is it more complicated than a traditional FE axle/CV?)
  13. GRich
    GRich Junior Member
    28
    16
    Had my driver side axle replaced at 34k. Took the dealer 5 tries to find the bad axle. No problems since.
  14. Mendel Leisk
    41,926
    I'm sure there's more to that story, but doesn't sound good, considering there's only 4 wheels on the car, lol.
    alanclarkeau likes this.
  15. jim240
    jim240 Junior Member
    24
    Reminds me of the look on my wife's face when she came out in the garage and her Rav4 was up in the air with all four wheels spinning while I was trying to find the bad wheel bearing with a stethoscope.
    Mendel Leisk and Raytheeagle like this.
  16. Mendel Leisk
    41,926
    Which reminds me of The Exorcist, lol.
