Bad Cells?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Adamo, Sep 4, 2021.
  1. Adamo
    Adamo New Member
    Prius 2010
    I think I have bad cells in the first two blocks as they seem different than the others. I also have three errors codes. Oh, and I can only run the car in power mode. It won't start/move otherwise. Also error codes: P0B3D and P0B42 (two of these). Unfortunately I've driven the car infrequently over the last year or so since I now work from home.
    Does this graph look normal or should I just take it to Toyota and have them check it out?
    TIA
    49,435
    you might need tech stream, or a dealer.
    how many miles on her?
    how is the 12 volt health?
  3. Adamo
    Adamo New Member
    The Aux 12V is fine; just replaced a couple of months ago. I think I'm near 70k miles.
