Bad drive pack on 07 Prius with 220000 miles on it
Discussion in 'Gen 2 Prius Main Forum' started by DMajor, Mar 30, 2021.
  1. DMajor
    DMajor New Member
    The drive battery on our 07 Prius went bad. Considering selling it as is
  2. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    Texas encompasses a decent sized area, which metroplex is closest to you?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Yes. And......????
  4. DMajor
    DMajor New Member
    DFW
  5. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    For 950 you can get a decent used HV battery with 1yr / unlimited mile warranty, with free install at : http://texashybridbatteries.com/
    For 995 you can get a decent used HV battery with 2yr / 50k miles warranty, with free installation at : http://hometownhybrids.com/
    Both should clean the HV battery fan, and possibly the MAF sensor and throttle valve. But inquire about the MAF / throttle valve.
    Both can be trusted if you want to keep the vehicle on the road, but only you would know if this used vehicle will go the distance.
    If it can go the distance (maybe 10+ more years?), then you might want to install a new OEM for 2250+ at either of the above instead.
