Bad gas tank bladder?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 9, 2024 at 12:44 PM.
  1. ski.dive
    ski.dive Active Member
    911
    233
    Hutchinson Island,FL. Mt. Snow,VT
    ***My gas gauge started blinking:(
    -I only got 223 miles from my last fill up
    **Bladder is only allowing 6.5 gallons at fill up
  2. Tombukt2
    Tombukt2 Senior Member
    9,798
    1,711
    Durham NC
    That's not the bladder that's allowing or not allowing that The bladder is just there on top of the tank to help control fumes and outgassing of said fumes and vapors into the atmosphere The check valves and associated plumbing could be fubar and any of those valves that are closed when they should be open and so forth will cause this low filling The blinking business is possibly not related and is you're sending unit for the gas gauge they can blink for numerous reasons I'm guessing you're 12 volt and everything else is perfect so on the six and a half gallons you're going whatever the mileage you said above? Usually when this has happened to me and two of these cars I got under the car with a rubber mallet and banged on the bottom of the tank all around the bottom of the tank boom boom boom we're not trying to put huge dents in the tank or any dents in the tank or anything like that just trying to dislodge any garbage or crap that may be on the slider or whatever works the gas gauge float mechanism
    49,761
    you'll never know if you filled up too soon, or ran out too soon.
