  1. Ashyukun
    Ashyukun Junior Member
    38
    Lexington, KY
    Since my 2005 Prius was down below half on the fuel gauge, I stopped in at the grocery store gas station on my way home and filled up. After filling it up, both on the short hop into the store parking lot to shop and the longer drive home the engine is shuddering and bucking BADLY- to the point that the check engine light was blinking until I backed off on the throttle and limped up the hill and coasted the rest of the way home. I pulled the codes and it had both cylinder 2 misfires as well as multiple cylinder misfires logged. It was perfectly fine before the fill-up, could something in or with the gas be causing it to run like its timing is WAY off?
    49,372
    sounds like it, how many miles on her?
  3. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    Are you absolutely certain you didn't put diesel in it? If you're sure, it sounds like some kind of contaminant is in there. Very suspicious that it would happen just after you gassed up if it was not the gas.
  4. Ashyukun
    38
    Lexington, KY
    No, I'm sure I didn't put diesel in- the pump handles are green for the diesel iirc, and it is also a lot pricier than the regular unleaded.
    So, I suppose the next question is: what to do about it?
  5. Patrick Wong
    18,200
    6,471
    Register a complaint at the gasoline station, and take your car to the local Toyota dealer to have the fuel removed from the fuel tank. The fuel line has to be disconnected and the fuel pump energized to drain the fuel.
  6. Yakoma
    470
    122
    ATL-ish
    If it turns out to be bad gas, that station should AT LEAST reimburse you for the tank. But I think you have a case for greater compensation to the tune of whatever the repairs are. Get some evidence from the shop.
    Oh, and if it was contaminated, there are others who would have had the same experience.
  7. bisco
    49,372
    save your gas receipt. you may want to talk to consumer affairs at the ag's office if the station balks.
  8. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    The reality is if it was bad gas then hundreds of other cars would have also had this issue. If you're in a small enough town where there are only a few usual suspect dealer service departments, then this particular batch of bad gas should be known about already.
  9. Yakoma
    470
    122
    ATL-ish
    Could be contaminated at the station during pumping or some kind of cross-contamination
  10. N.J.PRIUS
    N.J.PRIUS Member
    140
    50
    Fort Lee, NJ
    2013 Prius Plug-in
    When I lived in Delaware, an acquaintance of mine had a fuel delivery business with multiple trucks delivering gasoline and diesel to various filling stations. One of his drivers accidentially delivered gasoline into the diesel tank. The mistake was not caught until after a number of diesel cars started having problems after filling up at the diesel pumps! Could it be possible that you filled up with what you thought was gasoline but could have been in reality diesel?
  11. bisco
    49,372
    easy enough to go back to the station and pump a bit into a container.
  12. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    I'd be tempted to get a sample from your car gaso tank for analysis, but that takes a mechanic becuase I don't think you can get a tube down into the tank. Sounds like diesel or water. You should be able to ask station if they had a problem. Normally full 100% diesel mistake will stop you before you get out of the gas station, and is expensive repair I believe.
    #12 wjtracy, Jan 28, 2015
  13. GregP507
    GregP507 Senior Member
    3,002
    480
    When this happened to me, I went straight back to the gas station, where they sent me to their mechanic, offering to pay all costs. This is much easier than trying to fight them afterwards with unsupported accusations.
  14. GregP507
    3,002
    480
    In my case, someone messed-up filling the storage tanks with the wrong fuel.
  15. Yakoma
    470
    122
    ATL-ish
    Had a friend's daughter do it to her Acura recently by mistake...$400 at the dealer...had to flush and replace plugs and injectors, I believe. She only put $5 in, got down the street a few blocks and had the same experience as the OP until it died in the road.
  16. Ashyukun
    38
    Lexington, KY
    Well, had the car towed to the dealership this morning and we'll see what they come up with. I probably should have turned around and gone right back to the station but didn't think about that at the time. I did call them and complain as soon as I got home but largely got blown off by the whoever it was that answered the phone.
    Unfortunately I typically don't get receipts when I get gas, so don't have the receipt- it was however paid for with a debit card and I can see the transaction, and it should also be recorded in my Fuel Points usage for the Kroger card.
  17. GregP507
    3,002
    480
    And there's probably a video.
    Plan A is to get the dealer to acknowledge the problem.
    Plan B is to get a mechanic to verify the problem is bad fuel.
  18. Ashyukun
    38
    Lexington, KY
    So, finally heard back from the dealership... they're claiming that one of the plugs was loose and that the plugs weren't the right iridium plugs for the car, and that they couldn't find anything wrong with the fuel (though I don't know how closely they looked at it or tested it). I'm HIGHLY skeptical that all of a sudden MULTIPLE spark plugs would decide to not behave properly right after filling it up with gas- so once they've replaced the plugs and cleaned up the top of the engine (I'm still scratching my head as to how a loose spark plug would result in oil on the engine...) if it is STILL behaving the same way, I'm not letting them go on a (likely very expensive) witch hunt fixing whatever they think MIGHT be the problem.
    If need be, I'll have it towed (or if it is behaving well enough limp it home under its own power) home and look more into it myself. Or get it to the import shop in town that I have a good history with and actually trust...
  19. Yakoma
    470
    122
    ATL-ish
    Possible scenario, I think. Take one plug out of the equation and all hell breaks loose in the ignition sequence. Good to have the proper plugs in there now, but that in and of itself shouldn't have caused the failure you described - unless you just had those plugs replaced prior to the problem.
    Let us know how it runs and if it's fixed. If it's still not running right, I think I'd try to drain the tank myself and fill it with reliable fuel from another station.
    This one is intriguing - for us, at least. I know...aggravating for you. Sorry.
    :coffee:
  20. GregP507
    3,002
    480
    A loose spark-plug sounds lame. If it's loose enough to make a difference, it's going to either make a loud noise or fly out with much violence.
