Bad Gas
Discussion in 'Gen 2 Prius Fuel Economy' started by efrench515, Apr 19, 2006.
  1. efrench515
    efrench515 New Member
    53
    Saginaw, Michigan
    I have found that when I purchase gas at a particular station I average 10 MPG less that if I by it at other stations. I of course am not going to by gas at this station anymore. Has anyone else experienced such a great difference from one station to another?
  2. benighted
    benighted New Member
    530
    Westport, WA
    <div class='quotetop'>QUOTE(efrench515 @ Apr 19 2006, 04:59 PM) [snapback]242362[/snapback]</div>
    Is the station you are going to an Arco by any chance?
  3. efrench515
    53
    Saginaw, Michigan
    <div class='quotetop'>QUOTE(benighted @ Apr 19 2006, 08:18 PM) [snapback]242365[/snapback]</div>
    No, Speedy Q
  4. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    My wife has been buying gas from Sams and is averaging 45 mpg for both city & hwy... Im stumped..
  5. efrench515
    53
    Saginaw, Michigan
    <div class='quotetop'>QUOTE(priusguy04 @ Apr 19 2006, 09:38 PM) [snapback]242408[/snapback]</div>
    I have purchased Speedy Q 3 times each time my tank average droped to 36 MPG for the tank, refil elsewhere Back up to 46 for tank average
  6. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Could they be using the E10 stuff when everyone else isn't or something?
  7. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    The simplest explanation is that the station is cheating you by making their pumps inaccurate. That's a far easier explanation than concocting a different gas mix that gets lower milage.
    Gas is refined by very few companies -- all the stations in a given area buy from the same one or two refiners. Each "brand" of gas has its own package of additives added by the refiner, but the basic stock is exactly 100% identical -- it has to be, it's the same refiner!
    In California, they stopped enforcing weights and measures quite awhile ago. The stations now "self police" themselves. Sure they do. The result is that you can get widely different "milage" depending on which stations you frequent. They'd cheat you even more if they could get away with it, but 10% is about the limit of what people notice.
  8. eagle33199
    5,122
    268
    2015 Prius v wagon
    The MFD mileage shouldn't change if the pump doesn't measure it correctly, however, as the MFD measures based on distance traveled/volume consumed. So if the MFD mileage is whats dropping from that station, it would imply that there is something chemically different in the gas coming from that station, such as adding 10% ethanol, which many stations are doing (E10 is very commong, cars are starting to be designed to even work on E85)
  9. benighted
    530
    Westport, WA
    <div class='quotetop'>QUOTE(eagle33199 @ Apr 19 2006, 06:51 PM) [snapback]242418[/snapback]</div>
    No, I'm gettting 54 with E10
  10. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    <div class='quotetop'>QUOTE(benighted @ Apr 19 2006, 05:18 PM) [snapback]242365[/snapback]</div>
    I filled up at an Arco on Sunday and am currently achieving the highest mpgs I've ever gotten on a tank thus far: 49.2mpg so far over a distance of ~130 miles. Keeps going up steadily at about .4-.5mpgs/day. No complaints here yet!!
    Edited to add:
    Now I'm up to 49.5mpg and 151 miles into my tank of Arco gas. :)
  11. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    'Bad gas' is not restricted by brand or station. However, once burned, I don't go back to that station anymore...
  12. Rancid13
    2,452
    Completely understandable. I'd probably do the same thing if I was getting significantly lower mpgs than usual after filling up at any particular station, whether it be a specific Arco, Valero, Chevron, or Shell. I wouldn't boycott all stations bearing the same name, but I would make it a point to avoid that specific station, that's for sure!
  13. efrench515
    53
    Saginaw, Michigan
    I ado not think it has anything to do with pump modifications, When I fill up there it takes the amount of fuel I would expect. However the last and i do mean LAST tank I bought there only gave me 133 Miles on a holf tank of highway in 60 degree weather 33MPG ICK.
    I know it should make no difference since almost all gas in my area comes from the same shell refinery and even the same tanker delivers to Shell, BP, SUNOCO, ECT..... maybe it is something with their tanks having water seap in or something. I just know I am nover going there again.
