Bad Headlights -Gen II
Discussion in 'Gen 2 Prius Main Forum' started by swampchick, Sep 28, 2009.
  1. swampchick
    swampchick New Member
    Middleton, WI
    I have a 2008 Prius w/premium headlights. The lo-beam is awful. After checking them with a leveling test at the dealer, I am told that nothing can be done to improve the lo-beam coverage. I am wondering if anyone else has this problem? Are there good after-market light kits that can be used for this problem?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I assume you have HID lights. They can be adjusted upwards by you or the dealer. Just don't go too far or you'll get flashed by oncoming traffic.
  3. swampchick
    Middleton, WI
    Yes, I do have HID lights. Dealer claims that they are adjusted as high as they are designed to go. Lo-beam is still not very good. I often drive w/hi-beam on and seldom get flashed by on-coming drivers. Are you aware of any after market lights?
  4. firepa63
    1,761
    208
    No aftermarket lights... If you do a search on PriusChat, there are instrutions as to how you can adjust your lights higher. With the Prius, there is a severe cutoff with the headlights that takes some getting use to.
  5. swampchick
    Middleton, WI
    I took the car into the dealer today for the 3rd time. This time, they opened up the hood on the spot, took a screwdriver and made a few adjustments on the spot. We'll see how the lights look on the road tonight. Why they did not do this before is a mystery. Lazy perhaps.
  6. firepa63
    1,761
    208
    Let us know if there is an improvement.
  7. KTPhil
    KTPhil Active Member
    1,379
    They are easy to adjust yourself.
    Also, check that the auto-leveling sensor and motor are working correctly.
  8. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    You need an 8 mm wrench to adjust. Tighten to drop beam, loosen to raise beam
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I hate it when that happens. There sure are some fat ugly people out there. :eek:
