Bad key fob or trunk battery?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Maur2014PriV, Apr 12, 2023.
Tags:
  1. Maur2014PriV
    Maur2014PriV New Member
    Ohio
    2014 Prius v wagon
    I have a 2014 Prius V. I’m unsure if the smart key fob has failed or if the car battery in the trunk (not the hybrid ones) are my problem.
    What I have done: when it initially did not start, I didn’t know what to do as a new(er) hybrid owner, so I got a jump. It worked for a number of starts over the next couple of days.
    It didn’t start again with the brake depressed and the push start button. It didn’t make the little hum sound I’m accustomed to hearing upon opening the door either.
    I fumbled around- unsure what to do and opened and closed the door a couple times trying to figure out what to do. Then I tried again and it started.
    I replaced the 1632 battery in the smart fob- thinking maybe the fob just died. The car started a couple of times but is now not turning on after the fob battery is replaced.
    I’ve taken it to the auto parts store to see if they could use their diagnostic tool or their alternator health tool on my Prius but they cannot.
    There are no lights indicating engine problems and the hybrid battery health indicator looks as it always has- good.
    Is there a way to determine if the fob has failed or if it is the trunk battery that needs replaced?
  2. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    When this occurs and the fob battery is new or good, it is invariably a soft or failed 12V auxiliary battery.
    Maur2014PriV likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,590
    5,889
    Texas Hill Country
    You may have to take the aux battery out and have them load test it.
