bad mpg and hv battery
Discussion in 'Gen 2 Prius Main Forum' started by don m, Aug 17, 2016.
  1. don m
    don m Junior Member
    meadowview va
    does falling mpg indicate hv battery problems?
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    We need more, Don.
    How many miles does your 06 have? How bad is bad? 35 mpg?
    Has the HV battery ever been replaced?
    If your HV battery is original, the following applies
    Generally speaking, you will notice other issue in addition to the
    bad fuel economy. One is that the ICE will run more often and
    not shut off at stops as it once did. Another is the SOC gauge
    on the MFD will fluctuate from purple to green more frequently.
    If you have either of these, the HV battery is getting weak
    and will get weaker still until you'll get the red triangle of death
    and other warning lights on the dashboard.
    If and when that happens you will need to scan for codes and
    more often than not you'll get a P0A80 and/or P3011-P3024 codes.
    Robert Holt and johnjohnchu like this.
    49,488
    it's one of many, many possibilities. prius is an enigma, wrapped within a conundrum.
    'LectroFuel likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
  5. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    If you do really short trips under 5 miles or run AC on max it can reduce fuel economy. Let the car warmup for 5 minutes, then reset the mpg stats and drive for 30 miles at 62-65mph cruse set and see what MPG u get. Try to set the AC so the fan speed shows the lowest or next lowest setting. (78 degrees)
  6. bisco
    49,488
    your tyres are probably worn out.
  7. jadziasman
    1,355
    487
    District 6
    Don's tires would need to be worn to the rims to reduce fuel economy, b. Driving with worn tires actually increases mpg. But you knew that. You're just being snarky here, aren't you, since Don doesn't have much to say except "what's wrong". And he started another identical thread. I hope I'm not that lost at 88. Still 29 years away for me fortunately.
  8. bisco
    49,488
    nothing could be further from the proof.
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am still unsere why the OP asked almost the same thing twice but this one I can answer.
    No.
    There are many things that might be wrong with your 2006, one of which (say 5% of the cases) is the HV Battery. the other cases are almost all cheaper.
    When was the last time you replaced the 12 volt battery?
    When was the last time you had a wheel Alignment?
    How inflated are your tires?
    Is your engine being maintained? (oil and filter, air filter, PVC filter, spark plugs, etc.)
    Is the car acting different? (besides lower MPG)
    Are you driving more or less on some new route?
    Your answers to our questions may indeed point to the HV Battery, but nothing you have told us so far does.
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
    Robert Holt likes this.
  10. jadziasman
    1,355
    487
    District 6
    Do you recall his first and only post of this thread? He said his Prius has bad mpg but won't or can't say how bad.
    Some hypermiling fanatics would consider a 3% decrease devastating while an average car owner
    might consider a 33% hit troublesome. Who knows where Don is.
    Once Don wakes up from his third nap of the day and reads the two threads he started, maybe we'll get a response.
    Until then, I'm going to conclude he has some reason to suspect its the HV battery - the car is 10 years old after all.
    #10 jadziasman, Aug 18, 2016
    Shane Burns, 'LectroFuel and bisco like this.
  11. bisco
    49,488
    it's most likely the mpg.
  12. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Hahaha! Isn't he sleeping when he took his avatar picture? It's just an old car with an old battery. Mine is showing signs of wear. e.g. 39 MPG
    Shane Burns likes this.
  13. Franklin Ashley
    Franklin Ashley New Member
    West Los Angeles, Ca
    Three Touring
    Just got a 2007 how to tell which model and if battery has been changed. I buy cars at police auctions 69k on this one I like it but can't figure out how to get the alarm to work. After locking doors with with fob or door lock, I reach in unlock and Nada. Any suggestions are most welcome.
  14. JC91006
    16,482
    8,400
    There's no alarm
