Bad noise when motors switch
Discussion in 'Prius v Technical Discussion' started by danbob, Feb 3, 2013.
  1. danbob
    danbob Junior Member
    36
    Westchester NY
    So I cold started our V today and the electric motor turned on. When it switched over to the gas motor when I turned the heat on in the car, there was a violent plastic on plastic clunking or clanging type of noise. Sounded like something sheered itself off the motor. Then after about 5 seconds, it went away. Drove the car for a while, no check engine lights, no other weird noises, no problems. Engine seems like it has been ticking a bit in all this cold weather but I figure it was just lifter noise so I ignored it. Car is a 2012 with approximately 17k miles on it. Going to try to see if the same thing happens when I cold start it tomorrow morning in the frigid air. Car just had its 15k service and the dealer said it was perfect.....I don't get it. This noise was freeking loud. We LOVE this car btw...never thought I would say this about a hybrid because I am a HP nut, but this is the best, most functional car we have ever owned so far.
  2. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    My 2013 Prius v 1,400 miles did the same thing on a cold start. It sounded like something really bad was happening. It happened once last week and hasn't happened again. This is my first Prius and I know little about how they work but I suspect this has something to do with the the system starting the engine which usually happens a few seconds after I put the car in reverse to back out of the driveway.
  3. crpriusv
    crpriusv Junior Member
    43
    Delaware
    Same thing happened on my 2012 Prius v at around 4000 miles. Violent shaking and knocking when the ICE started after backing out of my garage. I shut it off then restarted and it shook again. The third time starting it was fine. I reported it to the service mgr at my dealer and he thought that maybe some water had gotten into the ignition system. The previous day I had washed my radiator with a hose running at a low flow rate to clean it after a 3000 mile trip.
    In any case the car now has 8000 miles and the incident has not repeated.
    49,371
    there are quite a few threads on this. it happens, nothing to worry about.
  5. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I've had this happen a few times now as well. 28,000 km on my v.
    First time it really freaked me out! Happens at anything from +5 to -25 celsius.
    I've learned a simple trick to prevent it happening from another comment in the gen 3 forum.
    Whenever powering on from a cold start just press on the gas pedal (no more than halfway down)as soon as the ready light stops flashing. Engine always starts up smoothly and with no knocking when I've done this.
  6. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    Going to guess the knock or noise is most likely water in the gas caused by the cold and phase separation of water/gas when it is an ethanol blend.
    Fuel School: Phase Separation in Ethanol Blended Gasoline
    If you are using a 10% blend, try switching to unleaded only if available in your area during colder months and see if the noise goes away.
